Hello Guest it is November 13, 2026, 12:48:57 PM
Author Topic: trouble with 4th/5th access limit switches  (Read 6755 times)
Offline BarryB
  •  267 267
« on: February 21, 2016, 06:43:12 PM »
Hey folks, I'm having trouble setting my limit switches for the 4th and 5th axis.  I had the mill set to use 2-9 on port 2 as inputs, and when I'd set one on 2 it would say it is also striking the other one that's set to 7.  If I reversed the settings, the same was true.  Then If I instead set to 13 and 15, I couldn't get either to say the limits were being hit.  Btw, when I say being hit, I'm just touching the ends of the wires together.  I'm not even going through a switch yet.  I wanted to make sure they work, before moving on.
Anyway, if you have an idea, let me know.  I'm excited to get my mill operational again after a year absence.  I knew I needed to rewire it, so I did, and it had shorts due to bad solder.  Now that's all fixed, it's almost operational, except for fixing the B/C axis!
Barry
