Hello Guest it is November 22, 2026, 07:13:43 AM
Author Topic: Chinese 6040 machine trouble cutting anything  (Read 10605 times)
« on: February 12, 2016, 06:43:22 PM »
Hi, thank you for looking.
I purchased a Chinese 6040 cnc router and for the past 4 months I have tried over and over again to cut a single piece of anything. I am at a complete loss and I don't know where else to turn to for help. I don't know any one that I could even pay for the help as I would if I had to. I have watched the help videos so many times and I have the machine set up according to the book and all the axis's operating like they should and I zero the Z and set the X and Y axis's as shown. All I ever get when I start cycle is it either just drills straight down or moves to position and does nothing and it doesn't cut.
I created a very simple circle pocket using cam software and even when I cycle start that, the bit just goes straight down. I am at a loss what to do next. I would gratefully appreciate your advise.
I have attached simple circle pocket I made but nothing works not even the sample gcode that comes with mach3.
Cheers,
Craig.
Code: [Select]
( Pocket 1 )
( File created: Wednesday February 10 2016 - 01:48 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 150.000, Y= 150.000 ,Z= 12.000)
(Toolpaths used in this file:)
(Pocket 1)
(Tools used in this file: )
(1 = End Mill {0.125 inch})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {0.125 inch})
N140G00G43Z20.000H1
N150S12000M03
N160(Toolpath:- Pocket 1)
N170()
N180G94
N190X0.000Y0.000F2540.0
N200G00X70.991Y82.539Z6.000
N210G1X70.991Y82.539Z-3.000F762.0
N220G3X70.203Y81.750I0.000J-0.789F2540.0
N230G3X70.991Y80.962I0.788J0.000
N240G3X71.780Y81.750I0.000J0.788
N250G3X70.991Y82.539I-0.789J0.000
N260G1X70.991Y83.809Z-3.000
N270G3X68.933Y81.750I0.000J-2.059
N280G3X70.991Y79.692I2.058J0.000
N290G3X73.050Y81.750I0.000J2.058
N300G3X70.991Y83.809I-2.059J0.000
N310G1X70.991Y85.079Z-3.000
N320G3X67.663Y81.750I0.000J-3.329
N330G3X70.991Y78.422I3.328J0.000
N340G3X74.320Y81.750I0.000J3.328
N350G3X70.991Y85.079I-3.328J0.000
N360G1X70.991Y86.349Z-3.000
N370G3X66.393Y81.750I0.000J-4.599
N380G3X70.991Y77.152I4.598J0.000
N390G3X75.590Y81.750I0.000J4.598
N400G3X70.991Y86.349I-4.599J0.000
N410G1X70.991Y87.619Z-3.000
N420G3X65.123Y81.750I0.000J-5.869
N430G3X70.991Y75.882I5.868J0.000
N440G3X76.860Y81.750I0.000J5.868
N450G3X70.991Y87.619I-5.868J0.000
N460G1X70.991Y88.889Z-3.000
N470G3X63.853Y81.750I0.000J-7.139
N480G3X70.991Y74.612I7.138J0.000
N490G3X78.130Y81.750I0.000J7.138
N500G3X70.991Y88.889I-7.139J0.000
N510G1X70.991Y90.159Z-3.000
N520G3X62.583Y81.750I0.000J-8.409
N530G3X70.991Y73.342I8.408J0.000
N540G3X79.400Y81.750I0.000J8.409
N550G3X70.991Y90.159I-8.409J0.000
N560G1X70.991Y91.429Z-3.000
N570G3X61.313Y81.750I0.000J-9.679
N580G3X70.991Y72.072I9.678J0.000
N590G3X80.670Y81.750I0.000J9.678
N600G3X70.991Y91.429I-9.679J0.000
N610G1X70.991Y92.699Z-3.000
N620G3X60.043Y81.750I0.000J-10.949
N630G3X70.991Y70.802I10.948J0.000
N640G3X81.940Y81.750I0.000J10.948
N650G3X70.991Y92.699I-10.949J0.000
N660G1X70.991Y93.969Z-3.000
N670G3X58.773Y81.750I0.000J-12.219
N680G3X70.991Y69.532I12.218J0.000
N690G3X83.210Y81.750I0.000J12.218
N700G3X70.991Y93.969I-12.219J0.000
N710G1X70.991Y95.239Z-3.000
N720G3X57.503Y81.750I0.000J-13.489
N730G3X70.991Y68.262I13.488J0.000
N740G3X84.480Y81.750I0.000J13.488
N750G3X70.991Y95.239I-13.489J0.000
N760G1X70.991Y96.509Z-3.000
N770G3X56.233Y81.750I0.000J-14.759
N780G3X70.991Y66.992I14.758J0.000
N790G3X85.750Y81.750I0.000J14.758
N800G3X70.991Y96.509I-14.758J0.000
N810G1X70.991Y97.779Z-3.000
N820G3X54.963Y81.750I0.000J-16.029
N830G3X70.991Y65.722I16.028J0.000
N840G3X87.020Y81.750I0.000J16.028
N850G3X70.991Y97.779I-16.029J0.000
N860G1X70.991Y99.049Z-3.000
N870G3X53.693Y81.750I0.000J-17.299
N880G3X70.991Y64.452I17.298J0.000
N890G3X88.290Y81.750I0.000J17.299
N900G3X70.991Y99.049I-17.299J0.000
N910G1X70.991Y100.319Z-3.000
N920G3X52.423Y81.750I0.000J-18.569
N930G3X70.991Y63.182I18.568J0.000
N940G3X89.560Y81.750I0.000J18.568
N950G3X70.991Y100.319I-18.569J0.000
N960G1X70.991Y101.589Z-3.000
N970G3X51.153Y81.750I0.000J-19.839
N980G3X70.991Y61.912I19.838J0.000
N990G3X90.830Y81.750I0.000J19.838
N1000G3X70.991Y101.589I-19.839J0.000
N1010G1X70.991Y102.859Z-3.000
N1020G3X49.883Y81.750I0.000J-21.109
N1030G3X70.991Y60.642I21.108J0.000
N1040G3X92.100Y81.750I0.000J21.108
N1050G3X70.991Y102.859I-21.109J0.000
N1060G1X70.991Y104.129Z-3.000
N1070G3X48.613Y81.750I0.000J-22.379
N1080G3X70.991Y59.372I22.378J0.000
N1090G3X93.370Y81.750I0.000J22.378
N1100G3X70.991Y104.129I-22.379J0.000
N1110G1X70.991Y105.399Z-3.000
N1120G3X47.343Y81.750I0.000J-23.649
N1130G3X70.991Y58.102I23.648J0.000
N1140G3X94.640Y81.750I0.000J23.648
N1150G3X70.991Y105.399I-23.648J0.000
N1160G1X70.991Y106.669Z-3.000
N1170G3X46.073Y81.750I0.000J-24.919
N1180G3X70.991Y56.832I24.918J0.000
N1190G3X95.910Y81.750I0.000J24.918
N1200G3X70.991Y106.669I-24.919J0.000
N1210G1X70.991Y107.939Z-3.000
N1220G3X44.803Y81.750I0.000J-26.189
N1230G3X70.991Y55.562I26.188J0.000
N1240G3X97.180Y81.750I0.000J26.188
N1250G3X70.991Y107.939I-26.188J0.000
N1260G00X70.991Y107.939Z6.000
N1270G00X70.991Y82.539Z6.000
N1280G1X70.991Y82.539Z-6.000F762.0
N1290G3X70.203Y81.750I0.000J-0.789F2540.0
N1300G3X70.991Y80.962I0.788J0.000
N1310G3X71.780Y81.750I0.000J0.788
N1320G3X70.991Y82.539I-0.789J0.000
N1330G1X70.991Y83.809Z-6.000
N1340G3X68.933Y81.750I0.000J-2.059
N1350G3X70.991Y79.692I2.058J0.000
N1360G3X73.050Y81.750I0.000J2.058
N1370G3X70.991Y83.809I-2.059J0.000
N1380G1X70.991Y85.079Z-6.000
N1390G3X67.663Y81.750I0.000J-3.329
N1400G3X70.991Y78.422I3.328J0.000
N1410G3X74.320Y81.750I0.000J3.328
N1420G3X70.991Y85.079I-3.328J0.000
N1430G1X70.991Y86.349Z-6.000
N1440G3X66.393Y81.750I0.000J-4.599
N1450G3X70.991Y77.152I4.598J0.000
N1460G3X75.590Y81.750I0.000J4.598
N1470G3X70.991Y86.349I-4.599J0.000
N1480G1X70.991Y87.619Z-6.000
N1490G3X65.123Y81.750I0.000J-5.869
N1500G3X70.991Y75.882I5.868J0.000
N1510G3X76.860Y81.750I0.000J5.868
N1520G3X70.991Y87.619I-5.868J0.000
N1530G1X70.991Y88.889Z-6.000
N1540G3X63.853Y81.750I0.000J-7.139
N1550G3X70.991Y74.612I7.138J0.000
N1560G3X78.130Y81.750I0.000J7.138
N1570G3X70.991Y88.889I-7.139J0.000
N1580G1X70.991Y90.159Z-6.000
N1590G3X62.583Y81.750I0.000J-8.409
N1600G3X70.991Y73.342I8.408J0.000
N1610G3X79.400Y81.750I0.000J8.409
N1620G3X70.991Y90.159I-8.409J0.000
N1630G1X70.991Y91.429Z-6.000
N1640G3X61.313Y81.750I0.000J-9.679
N1650G3X70.991Y72.072I9.678J0.000
N1660G3X80.670Y81.750I0.000J9.678
N1670G3X70.991Y91.429I-9.679J0.000
N1680G1X70.991Y92.699Z-6.000
N1690G3X60.043Y81.750I0.000J-10.949
N1700G3X70.991Y70.802I10.948J0.000
N1710G3X81.940Y81.750I0.000J10.948
N1720G3X70.991Y92.699I-10.949J0.000
N1730G1X70.991Y93.969Z-6.000
N1740G3X58.773Y81.750I0.000J-12.219
N1750G3X70.991Y69.532I12.218J0.000
N1760G3X83.210Y81.750I0.000J12.218
N1770G3X70.991Y93.969I-12.219J0.000
N1780G1X70.991Y95.239Z-6.000
N1790G3X57.503Y81.750I0.000J-13.489
N1800G3X70.991Y68.262I13.488J0.000
N1810G3X84.480Y81.750I0.000J13.488
N1820G3X70.991Y95.239I-13.489J0.000
N1830G1X70.991Y96.509Z-6.000
N1840G3X56.233Y81.750I0.000J-14.759
N1850G3X70.991Y66.992I14.758J0.000
N1860G3X85.750Y81.750I0.000J14.758
N1870G3X70.991Y96.509I-14.758J0.000
N1880G1X70.991Y97.779Z-6.000
N1890G3X54.963Y81.750I0.000J-16.029
N1900G3X70.991Y65.722I16.028J0.000
N1910G3X87.020Y81.750I0.000J16.028
N1920G3X70.991Y97.779I-16.029J0.000
N1930G1X70.991Y99.049Z-6.000
N1940G3X53.693Y81.750I0.000J-17.299
N1950G3X70.991Y64.452I17.298J0.000
N1960G3X88.290Y81.750I0.000J17.299
N1970G3X70.991Y99.049I-17.299J0.000
N1980G1X70.991Y100.319Z-6.000
N1990G3X52.423Y81.750I0.000J-18.569
N2000G3X70.991Y63.182I18.568J0.000
N2010G3X89.560Y81.750I0.000J18.568
N2020G3X70.991Y100.319I-18.569J0.000
N2030G1X70.991Y101.589Z-6.000
N2040G3X51.153Y81.750I0.000J-19.839
N2050G3X70.991Y61.912I19.838J0.000
N2060G3X90.830Y81.750I0.000J19.838
N2070G3X70.991Y101.589I-19.839J0.000
N2080G1X70.991Y102.859Z-6.000
N2090G3X49.883Y81.750I0.000J-21.109
N2100G3X70.991Y60.642I21.108J0.000
N2110G3X92.100Y81.750I0.000J21.108
N2120G3X70.991Y102.859I-21.109J0.000
N2130G1X70.991Y104.129Z-6.000
N2140G3X48.613Y81.750I0.000J-22.379
N2150G3X70.991Y59.372I22.378J0.000
N2160G3X93.370Y81.750I0.000J22.378
N2170G3X70.991Y104.129I-22.379J0.000
N2180G1X70.991Y105.399Z-6.000
N2190G3X47.343Y81.750I0.000J-23.649
N2200G3X70.991Y58.102I23.648J0.000
N2210G3X94.640Y81.750I0.000J23.648
N2220G3X70.991Y105.399I-23.648J0.000
N2230G1X70.991Y106.669Z-6.000
N2240G3X46.073Y81.750I0.000J-24.919
N2250G3X70.991Y56.832I24.918J0.000
N2260G3X95.910Y81.750I0.000J24.918
N2270G3X70.991Y106.669I-24.919J0.000
N2280G1X70.991Y107.939Z-6.000
N2290G3X44.803Y81.750I0.000J-26.189
N2300G3X70.991Y55.562I26.188J0.000
N2310G3X97.180Y81.750I0.000J26.188
N2320G3X70.991Y107.939I-26.188J0.000
N2330G00X70.991Y107.939Z6.000
N2340G00Z20.000
N2350G00X0.000Y0.000
N2360M09
N2370M30
Re: Chinese 6040 machine trouble cutting anything
« Reply #1 on: February 12, 2016, 07:31:54 PM »
Well, the code looks to be OK.
Post the XML of your config. (rename it to something new or the forum wont accept it.
4 months ? ? ?
We gotta fix that !
Hang in there,
Russ
« Reply #2 on: February 12, 2016, 07:32:45 PM »
I suggest you start at a much less complex level  You are trying to do a circular pocket and using cutter compensation too (G43).  You need to verify your machine moves properly in the first place.  Position the tool someplace near the middle of the x y and z travels.  Use the zero button next to each DRO.  The machine should now use that as the reference. Go to the MDI screen.  Enter G0 X1, and hit enter. The machine should move the tool to the right 1 mm whether it is in incremental mode or absolute.  If you then try G0 X2 and it moves 2 more millimeters to show 3mm it is incremental mode, it added to the previous location. If it moves 1mm and shows 2mm it is abolute mode measured from the zero postition you set.  Try moving the Y and Z in the same way.  If it all works, and it the right direction and the correct distance then Mach 3 is likely set up okay.
Then try a program to cut around a rectangle, don't bother with tool compensation or any of that yet.  The moves if cutting material should leave a part undersized by the tool diameter.  If you use a Cam program you usually don't bother with tool diameter compensation (G42, G43) because the Cam program simply uses the tool diameter and calculates the correct offset.  It looks like you have vectrix outputting tool compensation and I would turn that off as it has lots of gotchas for the beginner.
Good luck
« Reply #3 on: February 13, 2016, 07:43:40 PM »
Thanks for the reply.
I went to the MDI part and did what you suggested. The X and Y axis's moved about 6 inches each way when I used that command. When I did it with the Z axis command, it moved down 1mm.
Craig.
« Reply #4 on: February 14, 2016, 11:54:57 AM »
Sounds like your steps per revolution settings are way off. If set correctly a move of 1 on a metric machine should be one millimeter. If you got 6 inches (150mm) you need to divide the steps per revolution by 150 or there abouts. Until you get this set correctly you won't be able to do any cutting.
