Hello Guest it is November 08, 2026, 01:45:22 AM
Author Topic: Arc ok signal in Mach4  (Read 17640 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Arc ok signal in Mach4
« Reply #10 on: February 16, 2016, 01:57:41 AM »
Sorry been snowed under this end,
Have a look at the example again, its using the switch command so you can convert this in lua to an if statement.
use it in the form of
rc = mc.mcSiganalWait..........
if rc == MERROR_TIMED_OUT then
disable machine and update history with error
else
continue with gcode
end
DazTheGas
