Hello Guest it is November 13, 2026, 02:02:47 PM
Author Topic: Fusion 360  (Read 21237 times)
Fusion 360
« on: February 11, 2016, 06:46:48 AM »
Hi all , is anybody here running fusion 360 with Mach 3 ? I seem to be having a few issues  :-\
Offline dude1
  •  1,253 1,253
Re: Fusion 360
« Reply #1 on: February 11, 2016, 01:00:55 PM »
yes what are your issues
Re: Fusion 360
« Reply #2 on: February 11, 2016, 01:02:36 PM »
mach 3 doesnt like the K codes generated within the g code , im new to this so dont know what to do
Re: Fusion 360
« Reply #3 on: February 11, 2016, 01:22:23 PM »
think ive got round the K thing but mach 3 doesnt seem to like the colons ?
Re: Fusion 360
« Reply #4 on: February 11, 2016, 02:25:09 PM »
Are you using a Mach3 post?
Re: Fusion 360
« Reply #5 on: February 11, 2016, 02:27:53 PM »
Could you please explain exactly what you mean ? this is my very first step into this  :-\
Re: Fusion 360
« Reply #6 on: February 11, 2016, 02:57:10 PM »
When you export the g-code, you select a post processor for your specific machine control. This  creates g-code that works for your specific machine. If you use the wrong post processor, there's a good chance that the g-code won't work.
Re: Fusion 360
« Reply #7 on: February 15, 2016, 10:07:48 AM »
Thanks , Got that bit sorted now :) But thats left me with another question im afraid , Can i change where the cnc starts to work on my design ? For example as thinks stand at the moment if i was to design a wagon wheel the cnc cuts round the outside first , is it possible to have the machine begin from a centre point and work out ?
Offline dude1
  •  1,253 1,253
Re: Fusion 360
« Reply #8 on: February 15, 2016, 12:52:30 PM »
you select the order it cut's in cam do your op's from where you wont them to cut, if you wont post a file you wont cut and the order you wont it cut and I will show you how to do it
Re: Fusion 360
« Reply #9 on: February 15, 2016, 12:58:37 PM »
