Hello Guest it is October 26, 2026, 03:28:50 AM
Author Topic: Mach3 VB Script Help  (Read 107581 times)
Re: Mach3 VB Script Help
« Reply #30 on: February 11, 2016, 05:01:37 PM »
Relative to    While Ismoving ()  and Wend        there is a rather long thread / discussion  about it.
Can find my notes on that thread or the thread itself. No I don't remember all the specifics.
BR549, ring any bells???
« Reply #31 on: February 11, 2016, 05:02:06 PM »
Now another thing Sleep() is NOT just about waiting it also frees up teh CPU during a wait state and can allow OTHER processes to run while the wait is going on OTHERWISE teh wait can HOG all teh CPU resources and nothing else can happen.
« Reply #32 on: February 11, 2016, 05:04:12 PM »
Your summarizing nicely Terry........ :-*
« Reply #33 on: February 11, 2016, 05:16:10 PM »
hIYA RICH. There were MANY discussions on it in past years.  BUT seeing how it will never ever be worked on again I don't see any point in cranking the discussion back up again. (;-)
« Reply #34 on: February 11, 2016, 05:26:40 PM »
Understand, don't want a discussion on it, but said differently, If one scripts  the ....following....things will work as intended......well for later versions of Mach anyway.
Carry On, ;)
« Reply #35 on: February 11, 2016, 05:30:48 PM »
OKAY OKAY So I was wrong my bad. I guess I have alot of reading up to do on this.
So BR549, Are you saying a Sleep() function is better to use than While IsMoving() Wend, because it will allow the Previous lines to finish executing?
Also, Do I need to recall G91 after I call a G0? Or is calling G91 once at the start okay?
Hows this
Code: [Select]
Message "Finding Circle Center"
CurrentFeed = GetOemDRO(818)
 If GetOemLed (825) <> 0 Then
      Message "Z-Plate is grounded, check connection and try again"
   Else
Code "G91"
Code "G31 X-7 F8"
While IsMoving()
Wend
X1 = GetVar(2000)
While IsMoving()
Wend
Code "G0 X" & .98*X1
Code "G31 X7 F8"
While IsMoving()
Wend
X2 = GetVar(2000)
While IsMoving()
Wend
Xc = (X1 + X2)/2
Code "G0 X" & XC       'as well is calling a variable in a code line acceptable? Need help with these lines
Code "G31 Y-3 F8"
While IsMoving()
Wend
Y1 = GetVar(2001)
While IsMoving()
Wend
Code "G0 Y" & .98*Y1
Code "G91 G31 Y3 F8"
While IsMoving()
Wend
Y2 = GetVar(2001)
While IsMoving()
Wend
Yc = (Y1 + Y2)/2
Code "G0 Y" & Yc
Code "G31 X-7 F30"
While IsMoving()
If X<.95*X1 Then SetFeedRate(F2)
Wend
X1 = GetVar(2000)
While IsMoving()
Wend
Code "G31 X7 F30"
While IsMoving()
If X>.95*XMax Then SetFeedRate(F2)
Wend
X2 = GetVar(2000)
While IsMoving()
Wend
Xc = (X1 + X2)/2
Code "G0 X" & Xc
ode "G31 Y-3 F30"
While IsMoving()
If Y<.95*YMin Then SetFeedRate(F2)      '<--- Do I need the () of While IsMoving to be around my If Then? Or is just before the Wend okay?
Wend
Y1 = GetVar(2001)
While IsMoving()
Wend
Code "G31 Y3 F30"
While IsMoving()
If X>.95*YMax Then SetFeedRate(F2)
Wend
Y2 = GetVar(2001)
While IsMoving()
Wend
Yc = (Y1 + Y2)/2
Code "G0 Y" & Yc
SetDro(XaxisDRO,0)
SetDro(YaxisDRO,0)
Code "G0 G53 Z-4"
Message "Circle Center Found"
« Last Edit: February 11, 2016, 05:47:46 PM by nissan20det »
« Reply #36 on: February 11, 2016, 05:36:31 PM »
Another thing to keep in mind IS Mach3's scripting language is Cypress Basic . It is NOT Visual Basic(VB)
« Reply #37 on: February 11, 2016, 05:38:21 PM »
Nissan......,
Not saying your wrong / whatever.
Rather,
Trying to get some of the knowledge available to you for the script.
You'll be even more dangerous than me in no time at all,  :D
« Reply #38 on: February 11, 2016, 06:07:36 PM »
LOL Rich no offence taken at all bud! Just saying I know my place here... I got alot to learn C++ is way different
« Reply #39 on: February 11, 2016, 06:12:19 PM »
Okay this doesnt work I'm in test phase as we speak.... touches and stops great but the last line doesnt work it just keeps going + forever
   Else
Code "G91"
Code "G31 X-7 F8"
While IsMoving()
Wend
X1 = GetVar(2000)
While IsMoving()
Wend
Code "G0 X" & X1*.98
Do I need a X3?
X3 = X1 * .98
then
Code "G0 X" & X3
okay this worked
   Else
Code "G91"
Code "G31 X-7 F8"
While IsMoving()
Wend
X1 = GetVar(2000)
While IsMoving()
Wend
X3 = X1*.90
Code "G0 X"&X3
End If
easier way?
« Last Edit: February 11, 2016, 06:20:12 PM by nissan20det »
