Hello Guest it is October 22, 2026, 04:38:28 PM
Author Topic: Y axis not moving or power up  (Read 9091 times)
« on: February 01, 2016, 08:14:19 PM »
Hi I am Kobus Minnaar and new to CNC. I building a CNC but got a problem and don't know if this is hardware or software. I send my Board a TB6560 3 axis to a electronic store and pay more to repair than i paid for it and still not working. My X axis and Z axis work correct and the led light come on when you power it up but the Y axis is dead, When you power it up there is nothing. They fitted a new Driver but it dont seem to be it. Is there any way to test the incoming signal to see if it power the drivers up
Re: Y axis not moving or power up
« Reply #1 on: February 01, 2016, 09:05:08 PM »
Sorry forgot, the DRO work and if I swap the motors over they work so it is the Y axis
  •  9,374 9,374
« Reply #2 on: February 02, 2016, 01:33:57 AM »
I suspect the problem lies with your circuit board.
However, if you post you .xml file - the one which is located in the Mach3 folder named <your profile>.xml (typically Mach3Mill.xml) we can check that you have Mach3 set-up correctly. Copy and rename the file to kminnaar.xml, use the forum 'Reply' button and select Additional Options' to post the file.
