Hello Guest it is November 24, 2026, 09:27:05 PM
Author Topic: How do you Cut a Slide Rail?  (Read 20131 times)
Offline Davek0974
  •  2,606 2,606
Re: How do you Cut a Slide Rail?
« Reply #10 on: January 11, 2016, 07:07:06 AM »
Unless the rails are big, I would just use an ultra-thin cut-off disc and cut it off, the end won't get hot enough to bother anything unless you really attack it with the disc, a lot of discs don't like coolant and it makes a mess.
Just ease through it and get it done ;)
« Reply #11 on: January 11, 2016, 10:41:00 AM »
Angle grinder usually fits with 4" grinding disc to do grinding or parting off on thin metal, like steel. Just make it clear, yes, no coolant is necessary.
It also can mount with 4" carbide teeth circular cutter, for parting off non-steel metallic material, likes aluminium, wood or etc.. For that applications, care must be taken not to hand-held the angle grinder to do cutting, dangerous!, mounting it rigidly in machine as mentioned previously. And, for aluminium cutting, coolant is necessary.
