Hello Guest it is October 20, 2026, 06:46:51 PM
Author Topic: Another strange axis movement: G37 and 4th axis  (Read 18836 times)
Re: Another strange axis movement: G37 and 4th axis
« Reply #10 on: January 10, 2016, 04:05:47 PM »
For multiple installation of mach versions:
I just rename the C:Mach3 folder to say Z66MACH3 and then just install the version I want to the default C:Mach3.
Easy to copy over  to the new version whatever I want fro some version ie; licenses.
This keeps everything separated, yet available should you want to return to a version.
Just a thought,
« Reply #11 on: January 13, 2016, 01:27:16 PM »
Now I've running both versions of Mach3 (066 and 062) and also two plugin versions: v10fb2 and v10r2d1d. The last one in combination with v062 seems to be okay with the g31 move and the 4th axis. But because it was an error which happend not every time, I'm monitoring.
