Hello Guest it is November 22, 2026, 10:14:13 AM
Author Topic: Mach 4 V2 Windows 10  (Read 49088 times)
Re: Mach 4 V2 Windows 10
« Reply #20 on: February 16, 2016, 06:27:40 AM »
Right,
Thanks to the advice on here, I've managed to download and run Mach4 OK (in demo mode) with AVG disabled, but now Mach4 will not accept the new licence code generated for this computer (yes running Mach4 as Administrator).
Once again no problem licencing Mill Wizard.
Any thoughts?
Nick.
« Reply #21 on: February 16, 2016, 07:11:39 AM »
The license is tied to the PC ID. If you change pc's you need a new license.
« Reply #22 on: February 16, 2016, 07:15:33 AM »
Log into your account at machsupport.com and you can generate a license for the new PC yourself.
« Reply #23 on: February 16, 2016, 03:59:44 PM »
Thanks, but read my post again, I'd already regenerated a new code for this (new) computer.
Anyway, I ended up uninstalling and then reinstalling Mach4 and it then accepted the licence code that I'd generated earlier.
Nick.
« Reply #24 on: March 20, 2016, 12:19:19 PM »
Hi
I just tried to load Mach4 V2 on my windows 10 pro machine and windows defender says Win32/Varpes.L!cl is ar trojan and has removed it. Mach4 will not load without this file. Is this really a virus or just defender thinks it is? I turned off windows defender and loaded Mach4 again and it runs fine. As soon as defender is activated it removes this file. Anyone have any suggestions?
Thanks Jan
« Reply #25 on: March 20, 2016, 03:50:03 PM »
Hi Jan,
I've not had any further virus/trojan warnings with the latest Mach4 build. My issues seemed to revolve around a conflict between AVG Antivirus and Mach. Since that computer was bought specifically to run my machine using Mach and Mill Wizard, I've uninstalled AVG, but left Windows Defender active.
Nick.
« Last Edit: March 20, 2016, 03:53:26 PM by nick952 »
« Reply #26 on: March 20, 2016, 05:07:25 PM »
If concerned about Windows 10 updates, you can always try disabling the Windows Update service..
Allan
Offline dude1
  •  1,253 1,253
« Reply #27 on: August 22, 2016, 02:43:19 PM »
you can only disable win 10 updates on pro not home
Offline Pedio
  •  200 200
« Reply #28 on: August 22, 2016, 03:57:40 PM »
On my windows 7 computer I was able to not agree to the Microsoft Licensing agreement and the Windows 10 upgrade went away. We will see if it stays gone.
« Reply #29 on: August 22, 2016, 04:05:01 PM »
If you have Windows 10 Home you can somewhat limit it if you connect to the net
using WiFi and tell Windows that it is a "metered" connection. Unfortunately this
currently does not work for a wired connection.
Steve Stallings
www.PMDX.com
