Hello Guest it is October 21, 2026, 10:53:13 AM
Author Topic: Custom plasma probing code?  (Read 37887 times)
Re: Custom plasma probing code?
« Reply #10 on: December 26, 2015, 04:24:39 PM »
You have the general idea with teh SUB.  Yes you CAN access the Values of a range of DROs through Gcode directly with #vars in the Gcode (;-).
There is a list here on the site somewhere I will look for it again. This comes up about every 2years or so (;-).
What exactly are you checking for in teh M900 ?? To see IF teh Z switch is stuck on ?? I would do this in teh M3 macro and eliminate teh M900 all together.
As to making the ouput active yo MAY want o consider doing this from Gcode and use a simple brain to do teh switching eliminating 2 more macros.
Simply have the Gcode Set a #var to either 0 or 1 and have the brain watch that dro # that is matched to teh #var.  That range should work both ways modify either one and it updates the other.
Now you have eliminated any problems or delays  that you could run into from using Mcodes .
Just a thought, (;-) TP
« Reply #11 on: December 26, 2015, 08:18:38 PM »
Dave if it helps the OEMdros 1000 - 1255 as supposed to be mapped to #Vars 15000 -15255.
Offline Davek0974
  •  2,606 2,606
« Reply #12 on: December 27, 2015, 02:46:52 AM »
Thanks for that, i will now need to read up on brains and #vars ;)
this is a post modded by CandCNC for their MP3000-DTHC2 system, the odd thing is M900 does not exist in my running Mach setup so I can only guess it does absolutely bugger all??
I did a search through my backup archive and i did find a M900.m1s - it has this in it
'code to stop a touch off if the Ohmic is stuck on
if IsActive(_8_) then
Response =  MsgBox ("Touch - Off sensor jammed.  Clear and hit RUN to continue ", 4 , "Clear Z Jam")
code "M00"
end if
but i don't use the post it was related too, might be some post code overhang from another version?
I guess it checks input 8 to see if it is on at the time it wants to start IHS and stops if so???
I had to modify the input number as bracket-eight-bracket seems to convert to a smiley :)
Might be easier to pull the code from the post to tidy up a bit?
So my HeightSense.tap now looks like...
#???? = 1
G28.1 Z3.000
G92 Z0.000
#???? = 0
G00 Z#15045
G92 Z0.000
M99
Need to find an unused DRO number for the brain to monitor
« Last Edit: December 27, 2015, 02:57:04 AM by Davek0974 »
Offline Davek0974
  •  2,606 2,606
« Reply #13 on: December 27, 2015, 02:57:25 AM »
code "M00"
end if
#? = 1
G28.1 Z3.000
G92 Z0.000
#? = 0
G00 Z#15045
G92 Z0.000
M99
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: December 27, 2015, 07:23:32 AM »
Ok, getting there now,
I have this as a Subroutine "HeightSense.tap"
#15239=1
G04 P0.5
G28.1 Z3.000
G92 Z0.000
#15239=0
G00 Z#15045
G92 Z0.000
M99
And the G-Code looks like,
N0190 M09 (Turn off extract fan)
N0200 M00 (Paused: Check the DTHC Settings - Hit RUN to continue)
N0210 G00 X36.000 Y17.475 Z15.000
N0220 M900 (Check for Z active) **this line will be removed soon - does nothing
N0230 M08 (Turn on extract fan)
N0240 M98 (HeightSense.tap)
N0250 G00 Z3.8000
N0260 M03
I tried to use a screen OEM LED numbered 1239 so i had a bit of bling but it would not work so i gave up on that and altered the brain to switch the output directly from the #15239 value and it works, the output has a button and LED on my screen anyway so i do get a little feedback as to where its at. I think this was the right way to go anyway as it's simpler.
One query - I pulled the var 1239/15239 from thin air - is there a way to see if vars are already used??????
As the G-code loads you can see it run the macro at each call so I guess thats good?
The brain was the easy part, almost ladder-logic and i'm used to that from PLC programming.
Hardware changes next, this will have to wait until I return to work as all my pneumatic stuff is there :( unless i get desperate and drive in to pick it up ;)
From measurements, a 40mm stroke cylinder at 45deg will give plenty of safety clearance when retracted, 10mm bore is plenty as no power is required, it can easily be bolted to a bracket using bolts already in place on the floating head - this makes it an easy task to fit and remove if it fails.
As it stands right now I still have made massive improvements I think as the probing and IHS is now relative to the machine and NOT the g-code so any mechanical changes will mean not having to recreate my stock code files over - nice :)
Thanks for the guidance, especially at this time of year, been a fun project so far.
« Last Edit: December 27, 2015, 07:25:20 AM by Davek0974 »
Offline Davek0974
  •  2,606 2,606
« Reply #15 on: December 27, 2015, 08:39:01 AM »
One thing i have just noticed is that as the code is loaded, it triggers the probe output as it is scanned  clearly a bad thing,
I think i need to add an additional condition to the brain but what is best to monitor???
Offline Davek0974
  •  2,606 2,606
« Reply #16 on: December 27, 2015, 10:35:44 AM »
Ok need more help here :(
been messing with the brain, i want to activate output3 only if #var15239 is = 1 AND the run led is on i.e. not loading code etc.
I have tried many variations and nothing seems to work here, I had two inputs - #15239 & LED804 then a >0 comparator on each then an AND then the output3 but this does nothing at all.
Any brain guru's around??
Can't be that complicated surely?
Offline Davek0974
  •  2,606 2,606
« Reply #17 on: December 27, 2015, 02:32:03 PM »
Sorted it, couple more hours of reading and testing and it works perfectly if you use the pass-thru option and don't do any comparative ops on the signals.
input1)
         )  -->Pass-thru--> AND --> output
input2)
« Reply #18 on: December 27, 2015, 08:48:04 PM »
For the most part you can look in the screen editor to see IF you have used OEMDROs 1000 -1255 as these are tied to #vars 15000 - 15255 internally.  Also you will figure out soon enough that you cannot reference from a macro #vars 15000 - 15255 with GetVar or setvar.  Art stopped allowing you to access them at about 13000 from CB. BUT you still can use Code" #15000 = XX" to set those VARs from a macro if you need to.
Soon enough you are going to figure out that you can do most of the CandCNC stuff without all the CandCNC stuff and even a bit MORE they don't want you to know. (;-)
Offline Davek0974
  •  2,606 2,606
« Reply #19 on: December 28, 2015, 03:02:08 AM »
Thanks TP,
I will double-check the screen editor for the used DRO's as suggested just to make sure.
I have no idea why that M900 was there as there was no M900 macro so i guess it was just skipped by Mach. For the most part the CandCNC stuff works well, I won't recommend them anymore due to an issue I had previously which they did not help me out with satisfactorily and even tried to extract more money from me to replace stuff that was not faulty.
Anyway, i think what i have in place now is an improvement and when I add the new hardware it may be better or not but at least how it is now makes making changes far easier.
