Hello Guest it is October 21, 2026, 11:39:18 AM
Author Topic: Help with machined parts wrong size  (Read 23319 times)
Re: Help with machined parts wrong size
« Reply #10 on: January 08, 2016, 05:48:36 PM »
Anybody have any other ideas what could be the problem.
« Reply #11 on: January 08, 2016, 05:56:03 PM »
You never responded to TP from reply #6.
Post the DXF and the GCode file you created.
Gotta start there.
Russ
« Reply #12 on: January 08, 2016, 06:44:10 PM »
Posting the file and gcode I don't believe will be helpful. I've tried this with different parts in different cam software and the results are the same. I also did what was asked regards hanging from climb to conventional path and the results from that have not changed.
« Reply #13 on: January 08, 2016, 06:45:30 PM »
Very well .... carry on. Must be mechanical then.
Russ
« Reply #14 on: January 09, 2016, 06:38:32 AM »
Given it's not the things you say it can't be Russ is right, it looks mechanical
 - Nick
