Hello Guest it is November 26, 2026, 07:19:28 PM
Author Topic: PCI EPP Parallel Port Card  (Read 10472 times)
Offline lemo
  •  135 135
« on: May 10, 2007, 10:44:20 AM »
Would it be beneficial to use a dedicated EPP Port card versus the on board Parallel port?
Lemo
Cut five times and still to short...
Re: PCI EPP Parallel Port Card
« Reply #1 on: May 10, 2007, 12:21:38 PM »
Sometimes the onboard ports have low voltage and dont work too well with Mach as the difference between High and Low is not as clearly defined. If you are having problems then yes a PCI card may help you out. Most PCI cards have the proper 5V but again some can be low.
Offline lemo
  •  135 135
« Reply #2 on: May 10, 2007, 03:25:05 PM »
I'm more concerned about the timing and throughput. Good to know about the voltage issue as well.
I am running into watchdog timer issues once in a while (switched them off now without visible problems) and wondered if a add on card would behave better.
Mach is a funny little animal... But now it starts to work REAL WELL on my DeskTop PC. Anyone interested in a great IBM Lap I bought  but can't use for Mach?
Lemo
