Hello Guest it is November 10, 2026, 01:57:37 AM
Author Topic: Macro Help  (Read 23450 times)
Re: Macro Help
« Reply #10 on: December 22, 2015, 11:45:03 AM »
ok, im back.  lol
I have tried your program idea and I keep getting a syntax error.   when I click ok it doesn't show me where the error is.  I just see the cursor next to "Lcnt1".   so im not sure if this is the problem or not.
how do you declare varibles in Cypress Enable?
Re: Macro Help
« Reply #11 on: December 22, 2015, 01:28:45 PM »
The only thing I see wrong is MessageBox  should be MsgBox  (;-)
Re: Macro Help
« Reply #12 on: December 22, 2015, 01:50:39 PM »
OOPS there is another error
  IF Lcnt >= 10000 then                                    ' Check the status of the Lcnt1 value IF it timed out then do stop function
SHould read as
  IF Lcnt1 >= 10000 then                                    ' Check the status of the Lcnt1 value IF it timed out then do stop function
Re: Macro Help
« Reply #13 on: December 22, 2015, 04:07:33 PM »
Now im having trouble with my turret motor controller.   can seem to make the motor work.
going to take motor out and see if theres a mechanical problem.
Re: Macro Help
« Reply #14 on: December 23, 2015, 04:37:32 PM »
Well, took the turret apart and found a screw was the problem, it was mechanically binding the rotating part of the turret. once I removed the screw everything went back to working.
Thank you for your help.  the macro program is working beautifully!!!   :)
the while loop is working good too.  I added msgbox(Lcnt1), and it would show me the count.  which was 173,000 or something close to that.  so I raised the count to 250,000 before the message would appear and its working fine.
Re: Macro Help
« Reply #15 on: December 23, 2015, 04:40:14 PM »
Good Job (;-) TP
