Hello Guest it is November 08, 2026, 12:30:37 PM
Author Topic: Motor will not jog at slow speed.  (Read 7692 times)
« on: November 25, 2015, 09:29:02 PM »
Had a motor lock up on me.
First thought the x axis screw was in a bind but enede up being  the motor locked up.
Order new motor and installed and now the x and y axis are acting like they are binding up when jogging at a slow speed bit when you get it over 60% they move. But when moving 100% they are fine.
Thought it was my g540 driver messed up put a spare one in and same problem Tried different setting and same issues.
Deleted mach 3 thinking maybe something got corrupted and reprogram everything same problems.
Screws turn fine when motors are powered off.
Also noticed with using the keyboard which is the only way i have to jog right now.
If i go in one direction x-  then go x+ the direction doesn't change if you click back and forth on each one it straight up. it does it in the y direction also.
here a link to a video showing my issues
https://youtu.be/QXgBrCcEI6I
« Last Edit: November 25, 2015, 09:32:54 PM by jaustin »
Re: Motor will not jog at slow speed.
« Reply #1 on: November 26, 2015, 06:46:41 PM »
Figured it out after stating to troubleshooting motor wiring.
Both the x and y axis wiring had a bad spot in them. Replaced wiring both axis working fine now.
Running a test cut now and see if I have all my setting back to where they need to be.
