Hello Guest it is November 18, 2026, 09:57:17 AM
Author Topic: THREADING  (Read 7895 times)
THREADING
« on: November 24, 2015, 07:34:07 AM »
Hi-
Just a general question on threading.    I know Mach 3 starts the spindle when it receives a pulse from the spindle sensor and that assures that the pass always starts in the same rotational position of the part.  As the cut progresses, does Mach 3 adjust spindle rpm to maintain the proper ratio to carriage travel, or does it adjust the carriage feed rate to match the spindle rpm?
Thanks MM
Re: THREADING
« Reply #1 on: November 24, 2015, 11:00:58 AM »
Mach varies the Z axis feed to synch with the spindle.
Milton from Tennessee ya'll.
