Hello Guest it is November 22, 2026, 06:49:23 AM
Author Topic: Mach 3 Not Allowing Multiple Codes Without Restarting  (Read 29107 times)
Re: Mach 3 Not Allowing Multiple Codes Without Restarting
« Reply #20 on: November 09, 2015, 04:10:44 PM »
Who did your lighting, an electrician?
Did he do equipotential bonding (grounding or earthing) at the same time?
Did he bond your table, or controller to the earth?
This is a bit of a long shot in that I know earthing is very controversial and can be different in different parts of the world.
(I'd still start off with the easy things itemised above first)
Rob
Rob
