Hello Guest it is November 22, 2026, 01:06:19 PM
Author Topic: Showing selected axis  (Read 46425 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Showing selected axis
« Reply #30 on: November 09, 2015, 01:57:30 PM »
Go to ftp and d/l development version
Daz
Offline Pedio
  •  200 200
« Reply #31 on: November 09, 2015, 02:37:14 PM »
Daz - I did a search for MPG on the site and did not find the wizard. Is there anywhere else I should be looking?
Peter
Offline Pedio
  •  200 200
« Reply #32 on: November 09, 2015, 02:39:56 PM »
Found it ftp://machsupport.com/Mach4/DevlopmentVersions/
I did not know these existed.
Peter
Offline Pedio
  •  200 200
« Reply #33 on: November 09, 2015, 03:34:53 PM »
Daz,
I got everything downloaded and followed your instructions. I tried setting the shuttlepro buttons to MPG1 Select X - MPG1 Select Y - MPG1 Select Z but nothing moved. I set the buttons to Jog/MPG1 select X - etc and the axis moved. I don't get the DRO color change with this. I looked at the code but could not figure out where to change it. I have it toward the end of the PLC script.
I am on 2797 if this makes a difference.
Peter
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #34 on: November 09, 2015, 04:16:00 PM »
I will have a look tmoro but as far as I know the shuttle plugin has changed again since I did that code.
Daz
Offline Pedio
  •  200 200
« Reply #35 on: November 19, 2015, 08:01:15 AM »
Daz - did you get a chance to look at the DRO changing color when the axis is selected on the new version of M4.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #36 on: November 19, 2015, 08:53:33 AM »
can u post what you have the button assigned to and what mpg in mach4 you have set and i will duplicate locally.
Daz
