Hello Guest it is September 12, 2026, 08:09:32 AM
Author Topic: LCam failed to initalize  (Read 15289 times)
« on: May 06, 2007, 11:04:38 AM »
Anyone else having problems after installing the new LCam with the program failing to initalize when started?
I have loaded it successfully on another computer but not the one that I use at the tool.  I have tried unsinstalling LCam and reinstalling several times.  When I click on the LazyCam icon it gives me the error: LaysCam.exe - Application Error  The application failed to initialize properly (0xc150002).  Click OK to terminate the application.
Todd
Re: LCam failed to initalize
« Reply #1 on: May 06, 2007, 03:22:33 PM »
Todd,
The same thing happened to me when I downloaded the Lazy Cam 2.0 program. I haven't been able to get it to run at all.
The older version still runs OK.
Mike
« Reply #2 on: May 06, 2007, 03:45:08 PM »
Thanks for the reply.  The older version is working for me also.  I guess I'll use that one.
« Reply #3 on: May 06, 2007, 03:46:03 PM »
See Arts note on yahoo
Quote:
One important note though, on one of my computers it refused to run, it turned
out to be a binding error in the OS, which is fixed by updating that computer to .net
platform 2.0. This is a microsoft upgrade to XP, and your system may, or may not,
require that update.. If yu do need it, here is the link.. http://www.microsoft.com/downloads/details.aspx?familyid=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
This fixed mine
« Reply #4 on: May 06, 2007, 04:18:15 PM »
rayg,
Thanks. That did it for me. I appreciate your help.
Mike
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #5 on: May 06, 2007, 04:39:40 PM »
Hi, All
Had the some problem with LC, The fix for me was set the Video acceleration in Windows to None.
Start, Control Panel, Display, Settings, select Monitor if you have more than one, Advanced, Troubleshoot, "Hardware acceleration".
Set it to, NONE, Apply, OK.
Worked Hear, Chip
« Reply #6 on: May 07, 2007, 09:35:20 PM »
I tried just changing the acceleration to none but that didn't do it on this computer.  I did however upgrade to the .NET 2.0 like was suggested and now it runs just fine.  I never would have thought to do that.  Thanks Todd
« Reply #7 on: May 07, 2007, 09:46:16 PM »
Sorry I forgot to put that you may need the .net stuff :(
Sorry about that guys!
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #8 on: May 08, 2007, 03:09:52 AM »
The download fixed mine as well.
