Hello
Guest
it is
November 25, 2026, 08:03:05 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Backlash when enabled, kills everything.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Backlash when enabled, kills everything. (Read 21657 times)
PW8697
51
Re: Backlash when enabled, kills everything.
Reply #10 on:
October 26, 2015, 01:39:48 PM »
Just found out something interesting. I have two laser systems, both use the Xulifeng-Mach3-USB-Motion-Card. They work fine with Backlash Compensation enabled or not. So, it has boiled down to the MK3 interface board and/or its drivers. I have contacted the company to see if there are updated drivers for the board. Otherwise I will get another Xulifeng board for my mill, as the other two are totally bulletproof and have had no problems with them at all.
Will keep you posted on what happens.
Pete
Logged
rcaffin
1,073
Reply #11 on:
October 26, 2015, 03:26:53 PM »
Step and Direction are both 0 on each axis.
Doesn't that mean the step and dir signals are going nowhere? Shouldn't they be assigned to some pins so they go out to the motor drivers?
Roger
Logged
PW8697
51
Reply #12 on:
October 26, 2015, 06:42:08 PM »
Roger, don't know what those numbers in Step pulse and Direction Pulse do in the motor tuning window. Mill has been running fine all along, so signals are getting to where they need to. Except with backlash compensation enabled, at least on this interface board.
Pete
Logged
rcaffin
1,073
Reply #13 on:
October 26, 2015, 06:46:14 PM »
Ah - misunderstanding! I thought you were referring to Ports&Pins.
Dir pulse width does not apply/matter. Ignore.
Step - well, should not matter, but try setting it to 1 or 2, just for LOLs?
Otherwise - geez, I dunno.
Logged
PW8697
51
Reply #14 on:
October 30, 2015, 03:17:19 PM »
Its been a few days and finally have the mill running with backlash compensation enabled. Ended up being the plugin for the interface card was incorrect. Took four or five tries with Automation Technologies tech support to get one that works. But got it running today. I now have to study up and see about running with exact stop or constant velocity and the pros and cons of each.
All in all the fix for this backlash compensation enabled deal was getting the correct driver.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
