Hello Guest it is November 19, 2026, 12:37:58 AM
Author Topic: Denford Orac tool changer problem.  (Read 9283 times)
« on: October 23, 2015, 02:45:26 PM »
Hi all,
I recently acquired a friends Denford Orac lathe which he had converted to run on mach3. Everything seems to work ok apart from the tool changer which once given a command rotates continuously and doesn't stop. I'm not sure if its a soft wear issue ( macro) or a sensor problem. Has anyone had such a problem or at least have an Idea what it could be?
Cheers John.
Re: Denford Orac tool changer problem.
« Reply #1 on: October 24, 2015, 06:56:23 AM »
What command are you using? By tool changer are you meaning a turret?
« Reply #2 on: October 24, 2015, 01:12:03 PM »
Hi Rich,
The code I input is T0101M6.
John.
« Reply #3 on: October 24, 2015, 05:50:49 PM »
So what is in the M6?
