Hello
Guest
it is
October 30, 2026, 01:30:26 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Thanks Chip!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Thanks Chip! (Read 25616 times)
thespindoctor
307
Thanks Chip!
on:
May 06, 2007, 07:23:45 AM »
Chip, you are a scholar and a gentleman! I can't thank you enough for helping me out of my Rutex, Pixie, Yaskawa servo quagmire! You give meaning to the word altruism.
Thanks so much!
Keith Clark
Logged
Chip
2,055
Gainesville Florida USA
Re: Thanks Chip!
Reply #1 on:
May 06, 2007, 06:23:12 PM »
Hi, Keith
Enjoyed helping (in a small way) you sorting it out.
You did all the hard work, Glad you didn't have to go to plan C or D-yna-mite.
Put it together, Post the funniest Video Clip's also.
Thanks, Chip
Logged
thespindoctor
307
Re: Thanks Chip!
Reply #2 on:
May 06, 2007, 07:05:51 PM »
I will get a video as soon as I have something good to show but there sure a lot of details to work out still.
In fact, I am now wondering how to tie in the Pixie error and reset switches. These are at 5v and active low so I am
thinking I can connect to my Estop circuit on the Campbell board to the error so that I would get an Estop
with the Pixie error? Then I have to reset the Pixie. The reset could be set with a momentary switch but
I would like it to be automatically reset when I reset Mach3. I have an output free and perhaps with a macro
the output could send a momentary signal to reset?
Keith
Logged
nwmachinest
4
Re: Thanks Chip!
Reply #3 on:
September 21, 2008, 08:37:27 PM »
Hi
I'm having a bit of a problem with my pixies
that is I find the instructions about the seriel port
confusing
I"m going form a db25 on the host to the pixies db9,
would anyone know how to wirer this
thanks
Ben
Logged
thespindoctor
307
Re: Thanks Chip!
Reply #4 on:
September 21, 2008, 09:26:16 PM »
Ben,
What is the question? I am not understanding what the problem is.
Keith
Logged
thespindoctor
307
Re: Thanks Chip!
Reply #5 on:
September 21, 2008, 09:33:00 PM »
Ben,
The serial port is connected from the Pixie card to the serial port of your computer. This is only used to set up the board and change the parameters as well as tune the motor using the PC. You must download the Pixie tuning program and run it from Windows with the serial port connected and the Pixie in tuning mode. Turn on tuning mode by pressing the switch on the Pixie board. Once the parameters and entered as you desire and the tuning parameters are set, you can save the settings from the turning software and then you don't need the serial cable anymore. Everytime you need to change a parameter or tuning, you have to reconnect the serial cable and run the tuning program. Does this answer your question?
Keith
Logged
thespindoctor
307
Re: Thanks Chip!
Reply #6 on:
September 21, 2008, 09:34:13 PM »
Ben,
You don't need a special cable, just a normal serial cable with the DB9 connector of proper gender on the Pixie side and whatever connector you need on the computer side.
Keith
Logged
nwmachinest
4
Re: Thanks Chip!
Reply #7 on:
September 21, 2008, 10:13:05 PM »
I tried a normal db9 cable with an adapter to db25 and got zip.
this is what the manual says.
Serial Port: Pin 2 Rx (from host) Output. RS232 level receive line. Host computer
Serial Port: Pin 3 Tx (to host) Input. RS232 level transmit line. Host computer
Serial Port: Pin 5 Gnd(1) RS232 return (ground). Host computer
Serial port pin 4 is connected to pin 6, and pin 7 is connected to pin 8 to simulate
hardware handshaking if necessary. Pin 9 of the serial port is not used by the Pixie.
6. The serial port can be connected to a different host than that which is supplying step
and direction. It only needs to be connected while tuning the motor or setting other
parameters.
these directions seem ...... confusing or I just duns
thanks ben
Logged
nwmachinest
4
Re: Thanks Chip!
Reply #8 on:
September 21, 2008, 10:23:44 PM »
all the other serial rs232 ports I've encountered have had instructions something like
db9 db25
1------------1
2------------2
3------------3
4 loop to6
5-----------7
so forth and so on
these instructions don't:(
Logged
Carnoustie, Scotland
Re: Thanks Chip!
Reply #9 on:
September 22, 2008, 04:12:33 AM »
You seem to be saying you are connecting the serial to the parallel port, is that what you are saying?
If so then I think you are meant to connect the pixie to a serial port for setting up.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
