Hello Guest it is November 22, 2026, 11:53:30 AM
Author Topic: M codes and mach4, is there still a hesitation same as m3? (Except m10/m11)  (Read 7615 times)
As per title, when using m codes to toggle outputs is there still a hesitation with mach4, the same as there was with mach3, hence the reason why the m10/m11 codes were used as they were suppose not to have the delay / hesitation?
Was this not to do with the loop speed in mach3
(Question is to do with THC on and off control where a divot was created with the torch pause / hesitation during the m code processing)
Rob
Rob
  •  9,378 9,378
Hi Rob,
If it's any help, the Mach4 equivalent to the Mach3 M11Px/M10Px commands are...
M62Px turns Output# x ON
M63Px turns Output# x OFF
There are no delays associated with these commands as they take effect coincident with axis movement.
Tweakie, thanks very much, I'll give them a go
(Running a smooth stepper so that has its own challenges to see what's implemented and what's not, in mach3 only one output could be toggled with an m10/m11 regardless of the "Px" bit as the output is defined in the motion controllers config page)
Rob
Rob
