Hello
Guest
it is
October 20, 2026, 07:40:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
NF Circle cut wizard
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NF Circle cut wizard (Read 30605 times)
vmax549
on:
May 05, 2007, 06:55:17 PM »
Good Evening Ron, I was using the cut circle wizard today and noticed a quirk. As the bit is leading into the circle just before it starts to cut the radius it does a little jog out of the circle leaving a small dimple cut about .020 deep. It does it on every pass at the same spot. Could you check it out? Thanks Terry Parker
Logged
Ron Ginger
925
Re: NF Circle cut wizard
Reply #1 on:
May 07, 2007, 05:05:11 PM »
Can you tell me more- what dia cicrle, what tool dia, did you select inside or outside circle?
I suspect this is a function of the tool radius comp, related to your tool size and circle dia.
Logged
vmax549
Reply #2 on:
May 07, 2007, 09:02:11 PM »
Hi ROn,
2.750" dia Circle
3/8 bit 3 flute carbide
inside cut
cw rotation
conventional cut
I use it again today with a different setup and it worked fine?
? (;-) TP
Logged
Print
Pages:
1
Go Up
« previous
next »
