Hello Guest it is September 28, 2026, 11:29:46 AM
Author Topic: tapping head cycle?  (Read 39528 times)
CNC NEWBEE
Re: tapping head cycle?
« Reply #10 on: March 07, 2006, 11:57:09 PM »
well, all the holes are done! the feed rate matched the tap head perfect.
thanks again for the leg up on sub routines.
jh
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: March 08, 2006, 03:49:57 AM »
Not just a pretty face, sorry about the picture couldn't thing of owt else to put up there  ::)
« Reply #12 on: March 08, 2006, 05:11:16 AM »
Nice you are getting real work done! You have to love it when you can just sit back and see the holes get taped :) I was doing 4-40 holes at 1500 RPM at work, Taping is WAY faster than drilling the holes if it is done with the right tap.
www.newfangledsolutions.com
www.machsupport.com
CNC NEWBEE
« Reply #13 on: March 08, 2006, 10:12:39 AM »
That's for sure.
The material was 1.5"  thick cast aluminum tooling plate. That stuff is soo gummy.  I had to use a deep hole cycle with a .1" peck! tapping took two hours, the drilling took almost 7 hous!
Now that the tooling bed is done and bolted to the mill table I'm on to tackling my first "real job" 50 fuelcaps for my business.
www.eti-fuelcel.com
This time it's 6061-t6 and carbide tools. I might be back soon with some new chalenges I expect. What everyone would qoute as a turning job with heavy second opp's on a mill, I'm doing everything on the mill less two operations.
jh
« Last Edit: March 08, 2006, 10:14:26 AM by cnc newbee »
Offline Bear
  •  15 15
« Reply #14 on: October 22, 2006, 03:13:01 PM »
Hi all,
out of curiosity ,instead of G4 ,shouldn't there be a G0 Z(+.2 or such) then G1 feedrate x2 ?
Bear
  •  2,785 2,785
« Reply #15 on: October 22, 2006, 03:30:40 PM »
Very old posting, have a look at the latest one.
http://www.machsupport.com/forum/index.php?topic=1551.0
Graham.
Offline Bear
  •  15 15
« Reply #16 on: October 22, 2006, 03:52:20 PM »
I  apologise,
unreservedly ,  with great regret, with much sugaring and sorrow.
as I read as the second post today.
 this insubordination ,   Will Not Happen Again   !
BEAR
