Hello Guest it is November 22, 2026, 01:38:43 PM
Author Topic: Mach4 New Tabs  (Read 20638 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach4 New Tabs
« Reply #10 on: November 12, 2015, 06:34:57 AM »
Its not bad install 2686 had a bug and using the set tab cures it.
scr.SetProperty('MainTabs', 'Current Tab', '0')  needs to be in startup script
Daz
« Last Edit: November 12, 2015, 06:38:34 AM by DazTheGas »
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach4 New Tabs
« Reply #11 on: November 12, 2015, 07:44:12 AM »
Actually just remembered, in 2686 it had to be moved to the PLC script and done in the first run section at the bottom of the script.
Daz
Re: Mach4 New Tabs
« Reply #12 on: November 12, 2015, 06:01:05 PM »
Thanks Daz!
I'll give this a try.
Leo
Re: Mach4 New Tabs
« Reply #13 on: November 12, 2015, 06:20:17 PM »
It worked!
Although my first attempt caused my chosen tab to keep re-selecting itself when I tried to click on any of the others.
Putting the sir.SetProperty('MainTabs', 'Current Tab', '0') statement within the test condition "if testrun==1" (or something like that) solved the problem.
Thanks again Daz.
