Hello Guest it is November 12, 2026, 04:34:35 PM
Author Topic: servo motors overheating and losing steps when jogging  (Read 13131 times)
« on: August 14, 2015, 08:02:11 PM »
Hello everyone this is my first post here.
I am troubleshooting this mill, using gecko 320x and a smoothstepper board, with a power supply kit from automation technologies.
Motors heat up very fast when on idle, and when i try to jog continually i get steps, even with the MPG i still dont get continuous movement. and sometimes it goes the opposite direction a couple of steps.
Any ideas?
-Ed
Re: servo motors overheating and losing steps when jogging
« Reply #1 on: August 14, 2015, 08:20:39 PM »
Also, am I supposed to connect the neutral coming off the motors to the chasis of my machine?
I connected the neutral coming off of the 110, to the chasis on my control box. Is that correct?
Then I put that neutral on an empty block, should I ground that neutral to my machine aswell?
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: August 16, 2015, 10:54:09 AM »
Personally speaking, i would say it sounds very odd or even dangerous to have connected the neutral to the chassis of any machine.
What motors are these?
Have you got a wiring diagram?
You say servos, have you carried out servo amp tuning yet? Servos need careful setup but it sounds like you have other problems here.
Offline mc
  •  384 384
« Reply #3 on: August 16, 2015, 02:50:48 PM »
Sounds like a tuning issue, with the motors continually oscillating/hunting for position at idle, which can very quickly overheat them.
Neutral would depend on exactly what the 'neutral' wire from the motors actually is, and where you are (some countries, neutral is tied to earth, but you generally wouldn't tie it locally to earth in a machine).
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: August 16, 2015, 03:41:34 PM »
That was the bit that worried me.
Offline mc
  •  384 384
« Reply #5 on: August 16, 2015, 03:50:09 PM »
In some countries/areas, 110V neutral is gnd.
110V often consists of one wire at 0V tied to Gnd, with two other wires at 55V, but 180deg out of phase, so you get 110V.
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: August 16, 2015, 03:56:26 PM »
I never knew that, similar to a contractors 240->110v isolating transformer over here, never more than 55v above ground, thanks.
In that case i would certainly be looking at servo amp gain/deadband tuning.
