Hello Guest it is November 11, 2026, 07:46:03 PM
Author Topic: about : allow thc up/down control  (Read 9493 times)
« on: August 10, 2015, 03:34:50 PM »
hi people
in the config >pins&ports>mill options
there  is thc area and a check box of allow thc up/down control
can any body explain how to identify the thc up / down output pins
and how this mechanism works
 ;D
Offline beefy
  •  138 138
Re: about : allow thc up/down control
« Reply #1 on: August 11, 2015, 09:09:02 PM »
THC UP & THC DOWN are not outputs, they are inputs.
Normally, an external torch height controller sends UP and DOWN signals to Mach, and then Mach will move the Z axis up/down accordingly.
To identify the THC UP/DOWN inputs, go to Config / Ports & Pins / Input Signals. There you will see which port and which pin is used for each one.
The tick box "Allow THC UP/DOWN Control Even When Not In THC Mode" is for when you have manual switches wired to the THC UP/DOWN inputs and you want to manually control the Z, even if THC is not switched on. This is typically done with oxy acetylene cutting where you may not have a THC control and you just adjust the Z height manually.
Google for the Mach2 Mill manual. It has a good explanation of how Mach THC works.
« Reply #2 on: August 14, 2015, 05:58:55 AM »
thanks brother
good explanation
