Hello Guest it is October 22, 2026, 01:53:17 PM
Author Topic: Shuttle Pro Plugin!!!!  (Read 20111 times)
Offline Azalin
  •  189 189
« Reply #10 on: February 03, 2018, 04:08:11 AM »
My ShuttlePro works fine except the inner wheel. The selected axis moves 1mm per pulse but I want it to move only one step per pulse. Is there a way to this? I've played with Mach4 mpg settings acceleration and velocity but it didn't help.
Sent from my MI 5s Plus using Tapatalk
Offline Azalin
  •  189 189
« Reply #11 on: February 04, 2018, 06:09:14 AM »
Found it.
Re: Shuttle Pro Plugin!!!!
« Reply #12 on: January 28, 2020, 11:02:11 AM »
Found it.
May I ask you how you managed to make the inner wheel work. I have the same issue where everything else is working (outer ring, every buttons,...)
Side question: do you guys know where the config/keymap for the shuttle is stored ?
Offline dws
  •  24 24
« Reply #13 on: January 28, 2020, 12:54:01 PM »
This video will show how to set up the inner wheel:
https://www.youtube.com/watch?v=lQmi6Q_iOAU
The keymap and gcode data is stored in the Machine.ini file for the profile that you are using.
David
« Reply #14 on: January 28, 2020, 01:25:35 PM »
Wonderful, thanks a lot for the prompt response. Have a great day
