Hello Guest it is October 04, 2026, 06:04:53 PM
Author Topic: How do I connect Mach3 to a Delta VFD using an USB UART to RS485 adaptor?  (Read 23529 times)
Brains is an internal function of mach3 so is the macropump.  They are NOT plugins. Like I said you need to get to reading the manuals and docs.
Re: How do I connect Mach3 to a Delta VFD using an USB UART to RS485 adaptor?
« Reply #11 on: September 26, 2017, 12:54:49 PM »
Does any know the wiring hookup from the 2 wire rs 485 adapter to the termanals on a delta vfd -b ?
« Reply #12 on: September 27, 2017, 01:08:07 AM »
page 2-14 of the Delta VFD-B User Manual shows a RJ45 port with the following pinout
Serial interface
1: EV 2: GND
5:Reserved
6: Reserved
3: SG-
4: SG+
Hope it helps
