Hello Guest it is November 13, 2026, 01:11:37 PM
Author Topic: Future of Mach3 ??  (Read 25122 times)
Re: Future of Mach3 ??
« Reply #10 on: July 11, 2015, 08:08:42 PM »
The BEST approach would be to be PCI or PCIe motion card. Eliminate the Eithernet/usb bottleneck control problem.  Tormach has the right idea eliminate the problem to begin with then you do not have to deal with it anymore. There was a reason PC monitors never went USB or eithernet and it should apply to Motion controllers as well.
AND yes Some modern CNCs do run eithernet BUT they also have 2-4 main CPUS to keep it all running together and in sync. We basically have 1.
Offline derek
  •  200 200
« Reply #11 on: July 11, 2015, 09:25:47 PM »
I wonder if the UC100 can handle the M10/11 commands.
Yes it can. At least according to the manual.
Offline beefy
  •  138 138
« Reply #12 on: July 13, 2015, 05:19:10 AM »
Checked out the manual and it also has torch height control inputs, to my surprise. The big test will be seeing how it actually handles the M10/11 commands and if it can process those commands as fast as a standard parallel port setup.
Offline derek
  •  200 200
« Reply #13 on: July 13, 2015, 05:23:22 AM »
Here is a video of it laser engraving.
https://www.youtube.com/watch?v=z01f-XYFSWs
I don't know if that applies to what you are doing but it's pretty cool nonetheless.
Offline dude1
  •  1,253 1,253
« Reply #14 on: July 13, 2015, 05:48:55 AM »
Mach 4 pp (Darwin) can do that to
  •  9,377 9,377
« Reply #15 on: July 13, 2015, 11:30:24 AM »
Maybe ??
Although laser engraving is handled well in Mach3 unfortunately Mach4 / Darwin still has some way to go.
