Hello Guest it is October 10, 2026, 04:37:15 PM
Author Topic: 2nd window  (Read 23388 times)
Re: 2nd window
« Reply #10 on: July 14, 2015, 11:14:47 PM »
Pedio, what color do you want the background and buttons to be? Hot pink and purple?
Re: 2nd window
« Reply #11 on: July 14, 2015, 11:22:20 PM »
 ;D
Offline dude1
  •  1,253 1,253
Re: 2nd window
« Reply #12 on: July 14, 2015, 11:43:50 PM »
that look`s cool you should make a female friendly screen set hot pink
Re: 2nd window
« Reply #13 on: July 15, 2015, 12:34:29 AM »
Try this Pedio. Put the *.mcs file in your Wizards folder and start mach4. When you maximize the window, the buttons should expand really big like you want plus being able to move the window to your second screen. Let me know...Hope this helps ya! --josh
Re: 2nd window
« Reply #14 on: July 15, 2015, 01:04:31 AM »
For all you hot pink lovers out there.... ;)
Offline dude1
  •  1,253 1,253
Re: 2nd window
« Reply #15 on: July 15, 2015, 02:31:55 AM »
very good sl works very well
Offline Pedio
  •  200 200
Re: 2nd window
« Reply #16 on: July 15, 2015, 03:33:52 PM »
Josh - Works great! I can even change back and forth from the main screen and the wizard without any apparent problems. Could I ask you to do a little formatting and add a few buttons? Attached is how my Jog screen already works. I have made the jog buttons very big and oriented them the way the machine is actually set up. Also, I have some Jog speed change buttons on this screen. I would like to add a BIG start and stop buttons on opposite sides of the screen. I guess what I am really saying is that this should really be a touch screen pendant! Damn creeping requirements...
I owe you a bottle of Woodford Reserve for the Woodford pendant. How do I get it to you?
On another note - I still can not get the display in the Jog box to change when I use a button to select another jog speed. It works fine if I use the cycle button - hmmmmm.
Peter
Offline dude1
  •  1,253 1,253
Re: 2nd window
« Reply #17 on: July 15, 2015, 03:58:53 PM »
sent Josh a pm with your email
