Hello
Guest
it is
November 23, 2026, 08:37:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Order of tabs in a window
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Order of tabs in a window (Read 14206 times)
Pedio
200
on:
July 04, 2015, 10:52:09 AM »
Is there a way I can move the Jog tab to be the first tab on the OperationsTabs window? I would like for this to be the first one to appear when I start the machine.
I have tried moving it in Screen Tree Manager but I have not had any success.
Peter
Screwie Louie
166
Re: Order of tabs in a window
Reply #1 on:
July 05, 2015, 09:11:52 AM »
Hi Pedio! Yep...you can do it in the screen tree manager. You have to take the other tabs before jogging and drop them to the end (or below jogging).
Pedio
200
Reply #2 on:
July 05, 2015, 02:40:28 PM »
I tried that and it was very erratic on how it worked. when I finally got it to work (and rebooted Mach4) all of the buttons on the tabs had disappeared??? I had a backup
DazTheGas
778
DazTheGas
Reply #3 on:
July 06, 2015, 05:26:38 AM »
In your screen load script place
function SetJogTab()
local inst = mc.mcGetInstance();
scr.SetProperty('OperationsTabs', 'Current Tab', '3')
end
In your PLC script place
if testcount == 5 then SetJogTab() end
DazTheGas <----- Dont put that ;-)
Screwie Louie
166
Reply #4 on:
July 06, 2015, 11:48:34 AM »
Ahhh, I see. So you set the OperationsTabs to display the jogging tab upon screen load by making the current tab = jogging tab.
Yah, I went back and my stuff was missing too. Sorry Pedio.
Thanx Daz. DazTheGas()
Screwie Louie
166
Reply #5 on:
July 06, 2015, 11:26:00 PM »
well technically, set current tab to 3 on the fifth scan of the PLC; to wit the PLC calls the function defined in the screen load up script....right?
DazTheGas
778
DazTheGas
Reply #6 on:
July 07, 2015, 12:15:22 AM »
yep its just a fallback to make sure the screen has finished loading first, had mixed results without it
DzTheGas
Pedio
200
Reply #7 on:
July 07, 2015, 04:42:08 PM »
Daz - Works! Thanks
Pedio
200
Reply #8 on:
July 07, 2015, 04:43:24 PM »
BTW - will I need to redo this the next time Mach4 is upgraded? I am starting to keep a list.
P
DazTheGas
778
DazTheGas
Reply #9 on:
July 08, 2015, 03:52:36 PM »
if your profile is wxmach then yes this will get overwritten, if you have a custom profile then you will be ok.
DazTheGas
Print
Pages:
1
Go Up
« previous
next »
