Hello Guest it is July 18, 2025, 06:53:46 PM
Author Topic: tool height probing  (Read 15389 times)
Offline dude1
  •  1,253 1,253
Re: tool height probing
« Reply #10 on: July 03, 2015, 03:10:35 AM »
I give up
« Reply #11 on: July 03, 2015, 03:24:40 PM »
local hsig = mc.mcSignalGetHandle(1,inst, ProbeSignal,mc.ISIG_INPUT11)
above line doesn't look right....if you want the handle to ISIG_PROBE is should be:
local hSig = mc.mcSignalGetHandle (inst, mc.ISIG_PROBE)
if mc.mcSignalGetState (hSig) == 1 then do something end
--on a side note, once I finish moving and reassemble my machine and equipment, I'll work on this for you....pending, I can get G31 working for me.
« Last Edit: July 03, 2015, 03:26:38 PM by Screwie Louie »
« Reply #12 on: July 06, 2015, 07:41:36 AM »
Look over, and try this one, and see if it works......
Scott
Offline dude1
  •  1,253 1,253
« Reply #13 on: July 06, 2015, 03:10:34 PM »
thanks scott that was a simple one
« Last Edit: July 06, 2015, 03:16:53 PM by daniellyall »
Offline dude1
  •  1,253 1,253
« Reply #14 on: July 06, 2015, 05:34:15 PM »
well it`s still not quite right it comes up with this now
mcLua ERROR: Lua: Error while running chunk
[string "C:\Mach4Hobby\LuaExamples\m1005.mcs"]:27: bad argument #2 to 'tonumber' (base out of range)
stack traceback:
   [C]: in function 'tonumber'
   [string "C:\Mach4Hobby\LuaExamples\m1005.mcs"]:27: in function 'GetRegister'
   [string "C:\Mach4Hobby\LuaExamples\m1005.mcs"]:45: in function 'm1005'
   [string "C:\Mach4Hobby\LuaExamples\m1005.mcs"]:112: in main chunk
I changed this
function GetRegister(regname, num)--Added the return type def param
      local rc;
      local inst = mc.mcGetInstance();
      local hreg = mc.mcRegGetHandle(inst, string.format("iRegs0/%s", regname));
      local ReturnValue = 0;
      if num == 1 then
         ReturnValue = tonumber(mc.mcRegGetValueString(hreg));
      else
         ReturnValue = mc.mcRegGetValueString(hreg);
      end
        return ReturnValue;
      end
back to this
function GetRegister(regname)
return mc.mcRegGetValueString(hreg)
end
and ran through fine but still with the no probe contact error
Offline Pedio
  •  200 200
« Reply #15 on: July 06, 2015, 06:21:38 PM »
Scott
stack traceback:
I changed this
      local rc;
      if num == 1 then
      else
      end
        return ReturnValue;
      end
back to this
end
Papa Bear - I tried putting the script into the "left up script" on the auto tool zero button on the Mach4 main screen. Nothing happens
I have the latest PMDX SmartBOB plugin that supports probing. I have assigned the digitizer to pin 15 and attached the touch plate. When I touch the magnet to the plate the probe LED lights.
Not sure if I need to do anything else. I am a newbie so please forgive me of my ignorance.
Offline Pedio
  •  200 200
« Reply #16 on: July 06, 2015, 06:23:54 PM »
I quoted the wrong thread - I used the Papa Bear script in the zip file.
Offline dude1
  •  1,253 1,253
« Reply #17 on: July 06, 2015, 06:37:26 PM »
it`s ok pedio it dont work yet
