Hello Guest it is November 22, 2026, 08:01:16 AM
Author Topic: Probs with RoutOut CNC Mill 2000  (Read 22132 times)
Re: Probs with RoutOut CNC Mill 2000
« Reply #10 on: June 21, 2015, 03:46:42 PM »
Nick,
Mike,
I see your using demo for Mach3. I also wonder if all you did was use the default xml file values??
1. Try changing your settings for dir and step in motor outputs as they are both high.
2. Are your units metric or imperial? Currently set as metric.
3. Know nothing about your machine but the steps per unit may be incorrect.
   Confirm via calculated values based on your machine or use the axis calibration
   feature via the setting Tab ( alt 6).
Also suggest you have a read of the Mach3 manual and also watch the available Mach videos.
This is definitely the place for free support of second hand equipment .
My reflection as follows..................Yeah, buy whatever then expect everybody else to do the work a user.
Don't give any info or links or whatever as the communities time is without value, don't read TFM, shoot they can educate me,
and on and on and on...................Gets old, Nick! May be I am getting old!
 ;D
« Last Edit: June 23, 2015, 06:55:30 AM by RICH »
« Reply #11 on: June 21, 2015, 07:46:37 PM »
Amen Rich, preach it brother. (;-) TP
« Reply #12 on: June 21, 2015, 07:49:17 PM »
Im sorry. have I upset someone. it was not intentional. my apologies to you sir.
« Reply #13 on: June 21, 2015, 10:31:20 PM »
amikel,
No you haven't...all is cool. ;)
We are just human and sometimes like to reflect on the moment as it replenishes our intentions. ::)
« Reply #14 on: June 22, 2015, 04:21:26 PM »
Nick,
Not me Sir!
Bought a license I did Sir!
 ;D
What I really meant was that it's a great community where most experienced users do pitch in and try to help if they see a problem which they can help with, though a lot of the load is inevitably taken by the resident Gurus ;-)
ATB,
Nick
