Hello Guest it is November 23, 2026, 07:35:09 AM
Author Topic: router missing steps  (Read 11972 times)
« on: June 06, 2015, 06:14:36 AM »
 Hello everyone,
               Setup a Job in the router yesterday things started off good and then went terribly wrong.  I  watched it for a while and things were working as they should so I left it to do some yard work. came back and to my horror I have holes where should be no holes and profiles all over the place. So Somewhere along the way I started loosing steps . I am using a hobbycnc pro driver board and I am running the latest version of Mach3 with the 2010 screen set. any ideas where to start to trouble shoot this? I checked the mechanics of the router first  and all seems ok.  Thanks.
Charlie
Regards
Charlie M.
Re: router missing steps
« Reply #1 on: June 06, 2015, 07:47:52 AM »
Was the machine running fine before or is this the first time you've used it?
« Reply #2 on: June 06, 2015, 07:59:32 AM »
 Hi Gerry,
   It seems that I have always had issues with missing steps. It was very small, until yesterday. I am talking it was off by a few inches.
Regards
Charlie M.
« Reply #3 on: June 06, 2015, 10:45:22 AM »
What are your velocity and acceleration settings?
Ballscrew or rack and pinion?
« Reply #4 on: June 06, 2015, 11:34:16 AM »
 I am using timing belt and pulley and my accel is 114 and  velocity is 119 in per minute
Regards
Charlie M.
« Reply #5 on: June 06, 2015, 01:44:04 PM »
Set your accels to 15 and see if that helps.
Is it a direct drive pulley on a belt?
« Reply #6 on: June 06, 2015, 02:37:37 PM »
 Hi Gerry,
        yes it is a direct drive pulley on a belt. its setup just like a Shapoko.
Regards
Charlie M.
