Hello Guest it is October 22, 2026, 11:47:48 PM
Author Topic: Touch Plate Issues-Please help  (Read 9709 times)
« on: June 01, 2015, 02:00:01 PM »
I am having difficulty setting up my touch plate and would appreciate any sound advice.  I have enabled the probe, port 1, pin 15 active low. The touch test light immediately comes on. When I cancel active low the light goes out.
My PMDX pin 15 light will light up as it should when I ground the touch plate, however this does not communicate to the Mach software. I have tried different cabling and different inputs with the same results. I have checked the grounds which seem fine.
Does this appear to be a communication error and would (should) a smoothstepper possibly rectify this situation?  Or am I likely to be overlooking a Mach setting?
Thank You
Greg
Re: Touch Plate Issues-Please help
« Reply #1 on: June 01, 2015, 02:59:33 PM »
What PMDX board?
I'd give PMDX a call or email, they should be able to get you straightened out right away.
« Reply #2 on: June 01, 2015, 03:07:00 PM »
Gerry;
Thanks, this is an older 122. I will give them a call. Does this sound like a board issue?
By the way I  love your dovetail software, just have not had much time to use it.
Greg
