Hello Guest it is November 22, 2026, 12:42:02 PM
Author Topic: MACH4 and ESS with homing issues  (Read 27288 times)
Re: MACH4 and ESS with homing issues
« Reply #10 on: June 06, 2015, 10:58:17 AM »
Working on a similiar Mach4 2015 IE: ATC for mach4? Please say yes!
« Reply #11 on: June 06, 2015, 11:14:22 AM »
Not for at least another year.
« Reply #12 on: October 01, 2015, 07:59:32 AM »
Hi All I am New Here and am just getting Started I built a machine and used Mach 3 in Demo Mode which worked fine until i hit the line limit.
So I decided to make the plunge and purchased  mach 4. I am now setting it up and can't get the machine to move when i click the  Ref all home. In the  Diagnostic page it says it's homing but none of the axis move. I have to hit stop to allow the axis to once again to move using the jog buttons. Am I missing something in the pins setup. Please Help!!
Can you think of things that should be checked.
Please make a list I could check.
Thanks all
Ill post a picture of my homemade machine when I get a chance.
« Reply #13 on: October 01, 2015, 12:00:08 PM »
That sounds like a restart of Mach4 is needed. If that doesn't fix it, then you have some of the settings wrong in Mach4 or ESS plugin.
« Last Edit: October 01, 2015, 12:02:13 PM by Grimey »
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #14 on: October 01, 2015, 12:54:12 PM »
Thanks all
Why not start a new thread, give a brief description of your setup and include your machine.ini as a lot of things can be discovered from this.
DazTheGas
