Hello Guest it is November 22, 2026, 09:12:07 AM
Author Topic: Lua Signal Table  (Read 29210 times)
Offline dude1
  •  1,253 1,253
Re: Lua Signal Table
« Reply #10 on: January 02, 2016, 06:16:49 PM »
your second end
« Reply #11 on: January 02, 2016, 06:28:45 PM »
your second end
No doubt I've been looking at it too long, but I'm not seeing the problem with any of the end's.
Offline dude1
  •  1,253 1,253
« Reply #12 on: January 02, 2016, 08:53:05 PM »
end, should be end
« Reply #13 on: January 02, 2016, 10:28:28 PM »
According to http://www.lua.org/pil/3.6.html, trailing commas are valid in Lua.  I tried deleting it anyway, but it didn't make a difference.
Offline dude1
  •  1,253 1,253
« Reply #14 on: January 02, 2016, 11:39:57 PM »
go back to how daz says to do it that example I posted was working when I tried it, they may have done some changes I can't get it to work properly.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #15 on: January 03, 2016, 04:30:14 AM »
You are trying to do it the old way, in your table your using the on_off but in your signal script your using state ,
Put your signal script back to how it was and use the already created table in the startup script and a signal like this
Code: [Select]
[mc.ISIG_INPUT63] = function (state)
   if (state == 1) then
       mc.mcCntlFeedHold(inst)
    else
    --    do something else or not
    end
end,
DazTheGas
« Reply #16 on: January 03, 2016, 09:52:18 AM »
The name of the variable doesn't matter.  It's a function parameter and can be called anything.  But I tried changing it to "state" anyway.  No difference.
