Hello Guest it is October 20, 2026, 11:31:41 PM
Author Topic: Mach3 Screen Problem  (Read 28942 times)
« on: October 24, 2005, 12:12:05 PM »
Hi Art
I contacted you about 1 week ago about a problem I was having displaying the jpg bitmaps for Mach3.  I thought I would update you on this.  I reinstalled Windows XP and now the screens are displaying properly.
Nice to see a new forum outside Yahoo.
Larry Ragan
Art
Re: Mach3 Screen Problem
« Reply #1 on: October 24, 2005, 09:25:32 PM »
Thanks Larry,
 Weird how the OS influences that, I suspect its the video drivers..
Art
« Reply #2 on: November 21, 2005, 08:44:40 PM »
I'm Using a 15" LCD 1024x768 and I do not get the Whole Jog menu in Mach 3, when i press the tab key its on the right side but does not come in fully I only see about 1/2 of it. 1024x768.
Joe
Art
« Reply #3 on: December 04, 2005, 07:56:17 PM »
Hi Joe:
  Grab the edge of th ewindow and slide it to the right. Hit tab twice and repeat. It will remember that location from then on..
Art
ynneb
« Reply #4 on: December 05, 2005, 06:29:58 PM »
The problem with JPGs as opposed to BMPs is that JPGs can vary in DPI ( dots per inch)
Lets say you have a bmp that is 100 x 100 and you have a jpg100 x100 that has 75 dPI and another JPG 100 x100 150 DPI, even though they all have the same picture size, they will all display at different sizes in Mach. This is because Mach, unlike most picture displayers reads, the JPGS not by the picture display size, but by the DPI. I am not sure If Art was aware of the differences between BMPs and JPGs when he made mach able to display JPGs.
Having this display issue  causes many design problems.
ynneb
« Reply #5 on: December 05, 2005, 06:49:34 PM »
Try out these 3 attached same sized pictures.
While they will display correctly in the screen designer itself, Whe you go to run the screen in Mach you will see a completely different result.
I wish there was a crying out of frustration face, but this will have to do  :'(
