Hello Guest it is November 22, 2026, 04:23:03 PM
Author Topic: Defining Signal Scripts in Mach4  (Read 23655 times)
Offline TimGS
  •  108 108
Re: Defining Signal Scripts in Mach4
« Reply #10 on: May 18, 2015, 08:41:39 PM »
Made some progress today...
1)  I can now change the Jog Mode and update the Jog Tab Display and Jog "Cont" and "Step" LEDs to match the JOG Mode in sync with a SPST latching switch <Inc/Cont>.  I also played with the jog increment for when I add the 5 position switch.  <1, .1, .01, .001 and .0001>.  The "mc.mcJogSetInc(inst, mc.X_AXIS, 1)" works fine and it appears that the display is mapped to the X_Axis.   I could change the others and they worked independently of what the display showed until I clicked the display <Jog Inc> button.  I am thinking about using a register to implement the switch function; not sure yet though.
2) I can also change the state of the Machine to Enable but I haven't yet cracked the code for updating the button using the LUA script and not the tbutton2 "Input" field.  {I could use some advice here  ;D}
The following is the code to date:
Code: [Select]
SignalTable = {
    --Enable
    --[mc.OSIG_MACHINE_ENABLED] = function (state)
    --    machEnabled = state;
    --end,
    [mc.ISIG_INPUT0] = function (on_off)
        local inst= mc.mcGetInstance()
        local hsig = mc.mcSignalGetHandle(inst, mc.OSIG_MACHINE_ENABLED)
        if( on_off==1 ) then
            -- On
            mc.mcCntlEnable(inst, true);
            scr.SetProperty('tbutton2','State','Up');--This does not update display
        else
            -- Off
            mc.mcCntlEnable(inst, false);
            scr.SetProperty('tbutton2','State','Down');--This does not update display
        end
    end,
    [mc.ISIG_INPUT1] = function (on_off)
           local jogRate
            local hsig1 = mc.mcSignalGetHandle(inst, mc.OSIG_JOG_INC)
            local hsig2 = mc.mcSignalGetHandle(inst, mc.OSIG_JOG_CONT)
            mc.mcJogGetRate(inst, mc.X_AXIS, jogRate);
            -- On
            mc.mcJogSetType(inst, mc.X_AXIS, mc.MC_JOG_TYPE_INC);
            --mc.mcJogSetInc(inst, mc.X_AXIS, 1); --I will us this command when setting INC Later in another switch
            --Display INC number seems to track X_Axis setting though INC setting can be set for each Axis
            mc.mcJogSetType(inst, mc.Y_AXIS, mc.MC_JOG_TYPE_INC);
            mc.mcJogSetType(inst, mc.Z_AXIS, mc.MC_JOG_TYPE_INC);
            mc.mcJogSetType(inst, mc.A_AXIS, mc.MC_JOG_TYPE_INC);
            --Update Jog Display Tab LEDs
            mc.mcSignalSetState(hsig1, 1)--Real LED mapped to Jog Inc in MACH 4 Config
            mc.mcSignalSetState(hsig2, 0)
        else
            -- Off
            mc.mcJogSetType(inst, mc.X_AXIS, mc.MC_JOG_TYPE_VEL,jogRate);
            mc.mcJogSetType(inst, mc.Y_AXIS, mc.MC_JOG_TYPE_VEL,jogRate);
            mc.mcJogSetType(inst, mc.Z_AXIS, mc.MC_JOG_TYPE_VEL,jogRate);
            mc.mcJogSetType(inst, mc.A_AXIS, mc.MC_JOG_TYPE_VEL,jogRate);
            mc.mcSignalSetState(hsig1, 0) --Real LED mapped to Jog Inc in MACH 4 Config
            mc.mcSignalSetState(hsig2, 1)
        end
    end
sigNames = {
[mc.ISIG_EMERGENCY] = 'ISIG_EMERGENCY',
[mc.ISIG_INDEX] = 'ISIG_INDEX',
[mc.ISIG_INPUT0] = 'ISIG_INPUT0',
[mc.ISIG_INPUT1] = 'ISIG_INPUT1',
[mc.ISIG_INPUT10] = 'ISIG_INPUT10',
[mc.ISIG_INPUT11] = 'ISIG_INPUT11',
[mc.ISIG_INPUT12] = 'ISIG_INPUT12',
[mc.ISIG_INPUT13] = 'ISIG_INPUT13',
[mc.ISIG_INPUT14] = 'ISIG_INPUT14',
[mc.ISIG_INPUT15] = 'ISIG_INPUT15',
[mc.ISIG_INPUT16] = 'ISIG_INPUT16',
[mc.ISIG_INPUT17] = 'ISIG_INPUT17',
[mc.ISIG_INPUT18] = 'ISIG_INPUT18',
[mc.ISIG_INPUT19] = 'ISIG_INPUT19',
[mc.ISIG_INPUT2] = 'ISIG_INPUT2',
[mc.ISIG_INPUT20] = 'ISIG_INPUT20',
[mc.ISIG_INPUT21] = 'ISIG_INPUT21',
[mc.ISIG_INPUT22] = 'ISIG_INPUT22',
[mc.ISIG_INPUT23] = 'ISIG_INPUT23',
[mc.ISIG_INPUT24] = 'ISIG_INPUT24',
[mc.ISIG_INPUT25] = 'ISIG_INPUT25',
[mc.ISIG_INPUT26] = 'ISIG_INPUT26',
[mc.ISIG_INPUT27] = 'ISIG_INPUT27',
[mc.ISIG_INPUT28] = 'ISIG_INPUT28',
[mc.ISIG_INPUT29] = 'ISIG_INPUT29',
[mc.ISIG_INPUT3] = 'ISIG_INPUT3',
[mc.ISIG_INPUT30] = 'ISIG_INPUT30',
[mc.ISIG_INPUT31] = 'ISIG_INPUT31',
[mc.ISIG_INPUT32] = 'ISIG_INPUT32',
[mc.ISIG_INPUT33] = 'ISIG_INPUT33',
[mc.ISIG_INPUT34] = 'ISIG_INPUT34',
[mc.ISIG_INPUT35] = 'ISIG_INPUT35',
[mc.ISIG_INPUT36] = 'ISIG_INPUT36',
[mc.ISIG_INPUT37] = 'ISIG_INPUT37',
[mc.ISIG_INPUT38] = 'ISIG_INPUT38',
[mc.ISIG_INPUT39] = 'ISIG_INPUT39',
[mc.ISIG_INPUT4] = 'ISIG_INPUT4',
[mc.ISIG_INPUT40] = 'ISIG_INPUT40',
[mc.ISIG_INPUT41] = 'ISIG_INPUT41',
[mc.ISIG_INPUT42] = 'ISIG_INPUT42',
[mc.ISIG_INPUT43] = 'ISIG_INPUT43',
[mc.ISIG_INPUT44] = 'ISIG_INPUT44',
[mc.ISIG_INPUT45] = 'ISIG_INPUT45',
[mc.ISIG_INPUT46] = 'ISIG_INPUT46',
[mc.ISIG_INPUT47] = 'ISIG_INPUT47',
[mc.ISIG_INPUT48] = 'ISIG_INPUT48',
[mc.ISIG_INPUT49] = 'ISIG_INPUT49',
[mc.ISIG_INPUT5] = 'ISIG_INPUT5',
[mc.ISIG_INPUT50] = 'ISIG_INPUT50',
[mc.ISIG_INPUT51] = 'ISIG_INPUT51',
[mc.ISIG_INPUT52] = 'ISIG_INPUT52',
[mc.ISIG_INPUT53] = 'ISIG_INPUT53',
[mc.ISIG_INPUT54] = 'ISIG_INPUT54',
[mc.ISIG_INPUT55] = 'ISIG_INPUT55',
[mc.ISIG_INPUT56] = 'ISIG_INPUT56',
[mc.ISIG_INPUT57] = 'ISIG_INPUT57',
[mc.ISIG_INPUT58] = 'ISIG_INPUT58',
[mc.ISIG_INPUT59] = 'ISIG_INPUT59',
[mc.ISIG_INPUT6] = 'ISIG_INPUT6',
[mc.ISIG_INPUT60] = 'ISIG_INPUT60',
[mc.ISIG_INPUT61] = 'ISIG_INPUT61',
[mc.ISIG_INPUT62] = 'ISIG_INPUT62',
[mc.ISIG_INPUT63] = 'ISIG_INPUT63',
[mc.ISIG_INPUT7] = 'ISIG_INPUT7',
[mc.ISIG_INPUT8] = 'ISIG_INPUT8',
[mc.ISIG_INPUT9] = 'ISIG_INPUT9',
[mc.ISIG_JOGAN] = 'ISIG_JOGAN',
[mc.ISIG_JOGAP] = 'ISIG_JOGAP',
[mc.ISIG_JOGBN] = 'ISIG_JOGBN',
[mc.ISIG_JOGBP] = 'ISIG_JOGBP',
[mc.ISIG_JOGCN] = 'ISIG_JOGCN',
[mc.ISIG_JOGCP] = 'ISIG_JOGCP',
[mc.ISIG_JOGXN] = 'ISIG_JOGXN',
[mc.ISIG_JOGXP] = 'ISIG_JOGXP',
[mc.ISIG_JOGYN] = 'ISIG_JOGYN',
[mc.ISIG_JOGYP] = 'ISIG_JOGYP',
[mc.ISIG_JOGZN] = 'ISIG_JOGZN',
[mc.ISIG_JOGZP] = 'ISIG_JOGZP',
[mc.ISIG_LIMITOVER] = 'ISIG_LIMITOVER',
[mc.ISIG_MOTOR0_HOME] = 'ISIG_MOTOR0_HOME',
[mc.ISIG_MOTOR0_MINUS] = 'ISIG_MOTOR0_MINUS',
[mc.ISIG_MOTOR0_PLUS] = 'ISIG_MOTOR0_PLUS',
[mc.ISIG_MOTOR1_HOME] = 'ISIG_MOTOR1_HOME',
[mc.ISIG_MOTOR1_MINUS] = 'ISIG_MOTOR1_MINUS',
[mc.ISIG_MOTOR1_PLUS] = 'ISIG_MOTOR1_PLUS',
[mc.ISIG_MOTOR10_HOME] = 'ISIG_MOTOR10_HOME',
[mc.ISIG_MOTOR10_MINUS] = 'ISIG_MOTOR10_MINUS',
[mc.ISIG_MOTOR10_PLUS] = 'ISIG_MOTOR10_PLUS',
[mc.ISIG_MOTOR11_HOME] = 'ISIG_MOTOR11_HOME',
[mc.ISIG_MOTOR11_MINUS] = 'ISIG_MOTOR11_MINUS',
[mc.ISIG_MOTOR11_PLUS] = 'ISIG_MOTOR11_PLUS',
[mc.ISIG_MOTOR12_HOME] = 'ISIG_MOTOR12_HOME',
[mc.ISIG_MOTOR12_MINUS] = 'ISIG_MOTOR12_MINUS',
[mc.ISIG_MOTOR12_PLUS] = 'ISIG_MOTOR12_PLUS',
[mc.ISIG_MOTOR13_HOME] = 'ISIG_MOTOR13_HOME',
[mc.ISIG_MOTOR13_MINUS] = 'ISIG_MOTOR13_MINUS',
[mc.ISIG_MOTOR13_PLUS] = 'ISIG_MOTOR13_PLUS',
[mc.ISIG_MOTOR14_HOME] = 'ISIG_MOTOR14_HOME',
[mc.ISIG_MOTOR14_MINUS] = 'ISIG_MOTOR14_MINUS',
[mc.ISIG_MOTOR14_PLUS] = 'ISIG_MOTOR14_PLUS',
[mc.ISIG_MOTOR15_HOME] = 'ISIG_MOTOR15_HOME',
[mc.ISIG_MOTOR15_MINUS] = 'ISIG_MOTOR15_MINUS',
[mc.ISIG_MOTOR15_PLUS] = 'ISIG_MOTOR15_PLUS',
[mc.ISIG_MOTOR16_HOME] = 'ISIG_MOTOR16_HOME',
[mc.ISIG_MOTOR16_MINUS] = 'ISIG_MOTOR16_MINUS',
[mc.ISIG_MOTOR16_PLUS] = 'ISIG_MOTOR16_PLUS',
[mc.ISIG_MOTOR17_HOME] = 'ISIG_MOTOR17_HOME',
[mc.ISIG_MOTOR17_MINUS] = 'ISIG_MOTOR17_MINUS',
[mc.ISIG_MOTOR17_PLUS] = 'ISIG_MOTOR17_PLUS',
[mc.ISIG_MOTOR18_HOME] = 'ISIG_MOTOR18_HOME',
[mc.ISIG_MOTOR18_MINUS] = 'ISIG_MOTOR18_MINUS',
[mc.ISIG_MOTOR18_PLUS] = 'ISIG_MOTOR18_PLUS',
[mc.ISIG_MOTOR19_HOME] = 'ISIG_MOTOR19_HOME',
[mc.ISIG_MOTOR19_MINUS] = 'ISIG_MOTOR19_MINUS',
[mc.ISIG_MOTOR19_PLUS] = 'ISIG_MOTOR19_PLUS',
[mc.ISIG_MOTOR2_HOME] = 'ISIG_MOTOR2_HOME',
[mc.ISIG_MOTOR2_MINUS] = 'ISIG_MOTOR2_MINUS',
[mc.ISIG_MOTOR2_PLUS] = 'ISIG_MOTOR2_PLUS',
[mc.ISIG_MOTOR20_HOME] = 'ISIG_MOTOR20_HOME',
[mc.ISIG_MOTOR20_MINUS] = 'ISIG_MOTOR20_MINUS',
[mc.ISIG_MOTOR20_PLUS] = 'ISIG_MOTOR20_PLUS',
[mc.ISIG_MOTOR21_HOME] = 'ISIG_MOTOR21_HOME',
[mc.ISIG_MOTOR21_MINUS] = 'ISIG_MOTOR21_MINUS',
[mc.ISIG_MOTOR21_PLUS] = 'ISIG_MOTOR21_PLUS',
[mc.ISIG_MOTOR22_HOME] = 'ISIG_MOTOR22_HOME',
[mc.ISIG_MOTOR22_MINUS] = 'ISIG_MOTOR22_MINUS',
[mc.ISIG_MOTOR22_PLUS] = 'ISIG_MOTOR22_PLUS',
[mc.ISIG_MOTOR23_HOME] = 'ISIG_MOTOR23_HOME',
[mc.ISIG_MOTOR23_MINUS] = 'ISIG_MOTOR23_MINUS',
[mc.ISIG_MOTOR23_PLUS] = 'ISIG_MOTOR23_PLUS',
[mc.ISIG_MOTOR24_HOME] = 'ISIG_MOTOR24_HOME',
[mc.ISIG_MOTOR24_MINUS] = 'ISIG_MOTOR24_MINUS',
[mc.ISIG_MOTOR24_PLUS] = 'ISIG_MOTOR24_PLUS',
[mc.ISIG_MOTOR25_HOME] = 'ISIG_MOTOR25_HOME',
[mc.ISIG_MOTOR25_MINUS] = 'ISIG_MOTOR25_MINUS',
[mc.ISIG_MOTOR25_PLUS] = 'ISIG_MOTOR25_PLUS',
[mc.ISIG_MOTOR26_HOME] = 'ISIG_MOTOR26_HOME',
[mc.ISIG_MOTOR26_MINUS] = 'ISIG_MOTOR26_MINUS',
[mc.ISIG_MOTOR26_PLUS] = 'ISIG_MOTOR26_PLUS',
[mc.ISIG_MOTOR27_HOME] = 'ISIG_MOTOR27_HOME',
[mc.ISIG_MOTOR27_MINUS] = 'ISIG_MOTOR27_MINUS',
[mc.ISIG_MOTOR27_PLUS] = 'ISIG_MOTOR27_PLUS',
[mc.ISIG_MOTOR28_HOME] = 'ISIG_MOTOR28_HOME',
[mc.ISIG_MOTOR28_MINUS] = 'ISIG_MOTOR28_MINUS',
[mc.ISIG_MOTOR28_PLUS] = 'ISIG_MOTOR28_PLUS',
[mc.ISIG_MOTOR29_HOME] = 'ISIG_MOTOR29_HOME',
[mc.ISIG_MOTOR29_MINUS] = 'ISIG_MOTOR29_MINUS',
[mc.ISIG_MOTOR29_PLUS] = 'ISIG_MOTOR29_PLUS',
[mc.ISIG_MOTOR3_HOME] = 'ISIG_MOTOR3_HOME',
[mc.ISIG_MOTOR3_MINUS] = 'ISIG_MOTOR3_MINUS',
[mc.ISIG_MOTOR3_PLUS] = 'ISIG_MOTOR3_PLUS',
[mc.ISIG_MOTOR30_HOME] = 'ISIG_MOTOR30_HOME',
[mc.ISIG_MOTOR30_MINUS] = 'ISIG_MOTOR30_MINUS',
[mc.ISIG_MOTOR30_PLUS] = 'ISIG_MOTOR30_PLUS',
[mc.ISIG_MOTOR31_HOME] = 'ISIG_MOTOR31_HOME',
[mc.ISIG_MOTOR31_MINUS] = 'ISIG_MOTOR31_MINUS',
[mc.ISIG_MOTOR31_PLUS] = 'ISIG_MOTOR31_PLUS',
[mc.ISIG_MOTOR4_HOME] = 'ISIG_MOTOR4_HOME',
[mc.ISIG_MOTOR4_MINUS] = 'ISIG_MOTOR4_MINUS',
[mc.ISIG_MOTOR4_PLUS] = 'ISIG_MOTOR4_PLUS',
[mc.ISIG_MOTOR5_HOME] = 'ISIG_MOTOR5_HOME',
[mc.ISIG_MOTOR5_MINUS] = 'ISIG_MOTOR5_MINUS',
[mc.ISIG_MOTOR5_PLUS] = 'ISIG_MOTOR5_PLUS',
[mc.ISIG_MOTOR6_HOME] = 'ISIG_MOTOR6_HOME',
[mc.ISIG_MOTOR6_MINUS] = 'ISIG_MOTOR6_MINUS',
[mc.ISIG_MOTOR6_PLUS] = 'ISIG_MOTOR6_PLUS',
[mc.ISIG_MOTOR7_HOME] = 'ISIG_MOTOR7_HOME',
[mc.ISIG_MOTOR7_MINUS] = 'ISIG_MOTOR7_MINUS',
[mc.ISIG_MOTOR7_PLUS] = 'ISIG_MOTOR7_PLUS',
[mc.ISIG_MOTOR8_HOME] = 'ISIG_MOTOR8_HOME',
[mc.ISIG_MOTOR8_MINUS] = 'ISIG_MOTOR8_MINUS',
[mc.ISIG_MOTOR8_PLUS] = 'ISIG_MOTOR8_PLUS',
[mc.ISIG_MOTOR9_HOME] = 'ISIG_MOTOR9_HOME',
[mc.ISIG_MOTOR9_MINUS] = 'ISIG_MOTOR9_MINUS',
[mc.ISIG_MOTOR9_PLUS] = 'ISIG_MOTOR9_PLUS',
[mc.ISIG_PROBE] = 'ISIG_PROBE',
[mc.ISIG_PROBE1] = 'ISIG_PROBE1',
[mc.ISIG_PROBE2] = 'ISIG_PROBE2',
[mc.ISIG_PROBE3] = 'ISIG_PROBE3',
[mc.ISIG_SPINDLE_AT_SPEED] = 'ISIG_SPINDLE_AT_SPEED',
[mc.ISIG_SPINDLE_AT_ZERO] = 'ISIG_SPINDLE_AT_ZERO',
[mc.ISIG_THCDOWN] = 'ISIG_THCDOWN',
[mc.ISIG_THCON] = 'ISIG_THCON',
[mc.ISIG_THCUP] = 'ISIG_THCUP',
[mc.ISIG_TIMING] = 'ISIG_TIMING',
[mc.OSIG_AHOME] = 'OSIG_AHOME',
[mc.OSIG_ALARM] = 'OSIG_ALARM',
[mc.OSIG_ALIMITMINUS] = 'OSIG_ALIMITMINUS',
[mc.OSIG_ALIMITPLUS] = 'OSIG_ALIMITPLUS',
[mc.OSIG_BHOME] = 'OSIG_BHOME',
[mc.OSIG_BLIMITMINUS] = 'OSIG_BLIMITMINUS',
[mc.OSIG_BLIMITPLUS] = 'OSIG_BLIMITPLUS',
[mc.OSIG_BLOCK_DELETE] = 'OSIG_BLOCK_DELETE',
[mc.OSIG_CHARGE] = 'OSIG_CHARGE',
[mc.OSIG_CHARGE2] = 'OSIG_CHARGE2',
[mc.OSIG_CHOME] = 'OSIG_CHOME',
[mc.OSIG_CLIMITMINUS] = 'OSIG_CLIMITMINUS',
[mc.OSIG_CLIMITPLUS] = 'OSIG_CLIMITPLUS',
[mc.OSIG_COOLANTON] = 'OSIG_COOLANTON',
[mc.OSIG_CURRENTHILOW] = 'OSIG_CURRENTHILOW',
[mc.OSIG_DIGTRIGGER] = 'OSIG_DIGTRIGGER',
[mc.OSIG_DIST_TOGO] = 'OSIG_DIST_TOGO',
[mc.OSIG_DWELL] = 'OSIG_DWELL',
[mc.OSIG_ENABLE0] = 'OSIG_ENABLE0',
[mc.OSIG_ENABLE1] = 'OSIG_ENABLE1',
[mc.OSIG_ENABLE10] = 'OSIG_ENABLE10',
[mc.OSIG_ENABLE11] = 'OSIG_ENABLE11',
[mc.OSIG_ENABLE12] = 'OSIG_ENABLE12',
[mc.OSIG_ENABLE13] = 'OSIG_ENABLE13',
[mc.OSIG_ENABLE14] = 'OSIG_ENABLE14',
[mc.OSIG_ENABLE15] = 'OSIG_ENABLE15',
[mc.OSIG_ENABLE16] = 'OSIG_ENABLE16',
[mc.OSIG_ENABLE17] = 'OSIG_ENABLE17',
[mc.OSIG_ENABLE18] = 'OSIG_ENABLE18',
[mc.OSIG_ENABLE19] = 'OSIG_ENABLE19',
[mc.OSIG_ENABLE2] = 'OSIG_ENABLE2',
[mc.OSIG_ENABLE20] = 'OSIG_ENABLE20',
[mc.OSIG_ENABLE21] = 'OSIG_ENABLE21',
[mc.OSIG_ENABLE22] = 'OSIG_ENABLE22',
[mc.OSIG_ENABLE23] = 'OSIG_ENABLE23',
[mc.OSIG_ENABLE24] = 'OSIG_ENABLE24',
[mc.OSIG_ENABLE25] = 'OSIG_ENABLE25',
[mc.OSIG_ENABLE26] = 'OSIG_ENABLE26',
[mc.OSIG_ENABLE27] = 'OSIG_ENABLE27',
[mc.OSIG_ENABLE28] = 'OSIG_ENABLE28',
[mc.OSIG_ENABLE29] = 'OSIG_ENABLE29',
[mc.OSIG_ENABLE3] = 'OSIG_ENABLE3',
[mc.OSIG_ENABLE30] = 'OSIG_ENABLE30',
[mc.OSIG_ENABLE31] = 'OSIG_ENABLE31',
[mc.OSIG_ENABLE4] = 'OSIG_ENABLE4',
[mc.OSIG_ENABLE5] = 'OSIG_ENABLE5',
[mc.OSIG_ENABLE6] = 'OSIG_ENABLE6',
[mc.OSIG_ENABLE7] = 'OSIG_ENABLE7',
[mc.OSIG_ENABLE8] = 'OSIG_ENABLE8',
[mc.OSIG_ENABLE9] = 'OSIG_ENABLE9',
[mc.OSIG_FEEDHOLD] = 'OSIG_FEEDHOLD',
[mc.OSIG_HOMED_A] = 'OSIG_HOMED_A',
[mc.OSIG_HOMED_B] = 'OSIG_HOMED_B',
[mc.OSIG_HOMED_C] = 'OSIG_HOMED_C',
[mc.OSIG_HOMED_X] = 'OSIG_HOMED_X',
[mc.OSIG_HOMED_Y] = 'OSIG_HOMED_Y',
[mc.OSIG_HOMED_Z] = 'OSIG_HOMED_Z',
[mc.OSIG_JOG_CONT] = 'OSIG_JOG_CONT',
[mc.OSIG_JOG_ENABLED] = 'OSIG_JOG_ENABLED',
[mc.OSIG_JOG_INC] = 'OSIG_JOG_INC',
[mc.OSIG_JOG_MPG] = 'OSIG_JOG_MPG',
[mc.OSIG_LIMITOVER] = 'OSIG_LIMITOVER',
[mc.OSIG_MACHINE_CORD] = 'OSIG_MACHINE_CORD',
[mc.OSIG_MACHINE_ENABLED] = 'OSIG_MACHINE_ENABLED',
[mc.OSIG_MISTON] = 'OSIG_MISTON',
[mc.OSIG_OPT_STOP] = 'OSIG_OPT_STOP',
[mc.OSIG_OUTPUT0] = 'OSIG_OUTPUT0',
[mc.OSIG_OUTPUT1] = 'OSIG_OUTPUT1',
[mc.OSIG_OUTPUT10] = 'OSIG_OUTPUT10',
[mc.OSIG_OUTPUT11] = 'OSIG_OUTPUT11',
[mc.OSIG_OUTPUT12] = 'OSIG_OUTPUT12',
[mc.OSIG_OUTPUT13] = 'OSIG_OUTPUT13',
[mc.OSIG_OUTPUT14] = 'OSIG_OUTPUT14',
[mc.OSIG_OUTPUT15] = 'OSIG_OUTPUT15',
[mc.OSIG_OUTPUT16] = 'OSIG_OUTPUT16',
[mc.OSIG_OUTPUT17] = 'OSIG_OUTPUT17',
[mc.OSIG_OUTPUT18] = 'OSIG_OUTPUT18',
[mc.OSIG_OUTPUT19] = 'OSIG_OUTPUT19',
[mc.OSIG_OUTPUT2] = 'OSIG_OUTPUT2',
[mc.OSIG_OUTPUT20] = 'OSIG_OUTPUT20',
[mc.OSIG_OUTPUT21] = 'OSIG_OUTPUT21',
[mc.OSIG_OUTPUT22] = 'OSIG_OUTPUT22',
[mc.OSIG_OUTPUT23] = 'OSIG_OUTPUT23',
[mc.OSIG_OUTPUT24] = 'OSIG_OUTPUT24',
[mc.OSIG_OUTPUT25] = 'OSIG_OUTPUT25',
[mc.OSIG_OUTPUT26] = 'OSIG_OUTPUT26',
[mc.OSIG_OUTPUT27] = 'OSIG_OUTPUT27',
[mc.OSIG_OUTPUT28] = 'OSIG_OUTPUT28',
[mc.OSIG_OUTPUT29] = 'OSIG_OUTPUT29',
[mc.OSIG_OUTPUT3] = 'OSIG_OUTPUT3',
[mc.OSIG_OUTPUT30] = 'OSIG_OUTPUT30',
[mc.OSIG_OUTPUT31] = 'OSIG_OUTPUT31',
[mc.OSIG_OUTPUT32] = 'OSIG_OUTPUT32',
[mc.OSIG_OUTPUT33] = 'OSIG_OUTPUT33',
[mc.OSIG_OUTPUT34] = 'OSIG_OUTPUT34',
[mc.OSIG_OUTPUT35] = 'OSIG_OUTPUT35',
[mc.OSIG_OUTPUT36] = 'OSIG_OUTPUT36',
[mc.OSIG_OUTPUT37] = 'OSIG_OUTPUT37',
[mc.OSIG_OUTPUT38] = 'OSIG_OUTPUT38',
[mc.OSIG_OUTPUT39] = 'OSIG_OUTPUT39',
[mc.OSIG_OUTPUT4] = 'OSIG_OUTPUT4',
[mc.OSIG_OUTPUT40] = 'OSIG_OUTPUT40',
[mc.OSIG_OUTPUT41] = 'OSIG_OUTPUT41',
[mc.OSIG_OUTPUT42] = 'OSIG_OUTPUT42',
[mc.OSIG_OUTPUT43] = 'OSIG_OUTPUT43',
[mc.OSIG_OUTPUT44] = 'OSIG_OUTPUT44',
[mc.OSIG_OUTPUT45] = 'OSIG_OUTPUT45',
[mc.OSIG_OUTPUT46] = 'OSIG_OUTPUT46',
[mc.OSIG_OUTPUT47] = 'OSIG_OUTPUT47',
[mc.OSIG_OUTPUT48] = 'OSIG_OUTPUT48',
[mc.OSIG_OUTPUT49] = 'OSIG_OUTPUT49',
[mc.OSIG_OUTPUT5] = 'OSIG_OUTPUT5',
[mc.OSIG_OUTPUT50] = 'OSIG_OUTPUT50',
[mc.OSIG_OUTPUT51] = 'OSIG_OUTPUT51',
[mc.OSIG_OUTPUT52] = 'OSIG_OUTPUT52',
[mc.OSIG_OUTPUT53] = 'OSIG_OUTPUT53',
[mc.OSIG_OUTPUT54] = 'OSIG_OUTPUT54',
[mc.OSIG_OUTPUT55] = 'OSIG_OUTPUT55',
[mc.OSIG_OUTPUT56] = 'OSIG_OUTPUT56',
[mc.OSIG_OUTPUT57] = 'OSIG_OUTPUT57',
[mc.OSIG_OUTPUT58] = 'OSIG_OUTPUT58',
[mc.OSIG_OUTPUT59] = 'OSIG_OUTPUT59',
[mc.OSIG_OUTPUT6] = 'OSIG_OUTPUT6',
[mc.OSIG_OUTPUT60] = 'OSIG_OUTPUT60',
[mc.OSIG_OUTPUT61] = 'OSIG_OUTPUT61',
[mc.OSIG_OUTPUT62] = 'OSIG_OUTPUT62',
[mc.OSIG_OUTPUT63] = 'OSIG_OUTPUT63',
[mc.OSIG_OUTPUT7] = 'OSIG_OUTPUT7',
[mc.OSIG_OUTPUT8] = 'OSIG_OUTPUT8',
[mc.OSIG_OUTPUT9] = 'OSIG_OUTPUT9',
[mc.OSIG_PRTSF] = 'OSIG_PRTSF',
[mc.OSIG_REVERSE_RUN] = 'OSIG_REVERSE_RUN',
[mc.OSIG_RUNNING_GCODE] = 'OSIG_RUNNING_GCODE',
[mc.OSIG_SINGLE_BLOCK] = 'OSIG_SINGLE_BLOCK',
[mc.OSIG_SOFTLIMITS_ON] = 'OSIG_SOFTLIMITS_ON',
[mc.OSIG_SPINDLEFWD] = 'OSIG_SPINDLEFWD',
[mc.OSIG_SPINDLEON] = 'OSIG_SPINDLEON',
[mc.OSIG_SPINDLEREV] = 'OSIG_SPINDLEREV',
[mc.OSIG_TOOL_CHANGE] = 'OSIG_TOOL_CHANGE',
[mc.OSIG_TP_MOUSE_DN] = 'OSIG_TP_MOUSE_DN',
[mc.OSIG_XHOME] = 'OSIG_XHOME',
[mc.OSIG_XLIMITMINUS] = 'OSIG_XLIMITMINUS',
[mc.OSIG_XLIMITPLUS] = 'OSIG_XLIMITPLUS',
[mc.OSIG_YHOME] = 'OSIG_YHOME',
[mc.OSIG_YLIMITMINUS] = 'OSIG_YLIMITMINUS',
[mc.OSIG_YLIMITPLUS] = 'OSIG_YLIMITPLUS',
[mc.OSIG_ZHOME] = 'OSIG_ZHOME',
[mc.OSIG_ZLIMITMINUS] = 'OSIG_ZLIMITMINUS',
[mc.OSIG_ZLIMITPLUS] = 'OSIG_ZLIMITPLUS',
Offline dude1
  •  1,253 1,253
« Reply #11 on: May 19, 2015, 01:14:01 AM »
just been playing with your code since I cant get mine working set to num keys you are right about it working if in estop or not, something I found is set some jog keys and see what happens when in estop or not
