Hello Guest it is November 23, 2026, 07:09:08 AM
Author Topic: EStop Problem  (Read 9763 times)
EStop Problem
« on: May 01, 2015, 11:18:02 PM »
Ever since I added an Ethernet Smooth Stepper I've had a problem with my Estop. When I hit the Estop the G540 stops the steppers but Mach 3 continues to run. I have to manually stop Mach and reset everything. I have the Estop wired to pin 10 as per the gecko illustration. I know I just probably missed something on the setup, but for all my searching I can't find the missing step. Anyone have any ideas? I usually find all my answers here without posting so I guess I'm a lurker. I finally get to jump in.
Re: EStop Problem
« Reply #1 on: May 02, 2015, 01:54:46 PM »
Do you have the E-Stop set correctly in Ports and Pins? Not just the correct pin number but you also need the correct port number assigned. The ESS has 3 ports so it will depend which one you are connected to as to whether you have port 1, 2 or 3 set  for the E-Stop port.
Re: EStop Problem
« Reply #2 on: May 02, 2015, 08:15:01 PM »
Hood, you're the Guru. As usual you're right on. I just played with ports and pins until I hit the combo that worked.  Thank You.
Richard
Re: EStop Problem
« Reply #3 on: May 03, 2015, 07:08:04 AM »
Glad you got it :)
