Hello Guest it is November 13, 2026, 09:43:20 AM
Author Topic: Help with Plasma G31 Probe On Floating head  (Read 49345 times)
Re: Help with Plasma G31 Probe On Floating head
« Reply #20 on: April 04, 2017, 05:21:00 PM »
Hi all,
Brand new to the Mach scene.
I am busy setting up my CNC-Plasma and ran into a few hold-ups.
Specs: 2x Nema 34`s on y-axis, 1x Nema 34 on x-axis, 1x Nema 23 on z-axis. Proximity switches (NC; PNP 3-wire) for over-runs and homes. Mach3 Licensed, Sheetcam Licensed.
I got the y- and x- axis to work as required (I think), moving according to Mach`s Axes layout and homing correctly (again, I think).
My problem is with the z-axis, to get it to touch the material.
I have a NC Proxy installed so that when the floating head is in normal position, the proxy is open, so on moving downward (touch off), it will close.
According to what I understand from this thread, the touch-off proxy should be set as Z-home? Is that correct?
If so, then how will the Z-axis retract to the top (lets call it normal home) as to be out of the way when the gantry is homing?
Any help will really be appreciated.
« Reply #21 on: April 04, 2017, 05:39:54 PM »
With further research:
Some post say that a limit switch has been used as a probe...
Will a proxy work as a probe? So as to be activated on touch-off?
