Hello Guest it is October 21, 2026, 03:10:27 AM
Author Topic: two issues....  (Read 10859 times)
two issues....
« on: April 26, 2015, 10:56:11 AM »
After installing a different Mach 3 version, my cnc is acting funny regarding two issues.
One, for some reason the numeric keypad no longer works unless I use the MPG window with it. In my previous version, I was able to use the numeric keypad to move the axis.  I am not sure what needs to be done...
Two, until the upgrade, I was able to use the "run from here" command and have my job continue. Now, the same command sends the machine axis to the extremes. I am not sure what needs to be set in the config file in order to prevent this from happening.
thanks
tony
Re: two issues....
« Reply #1 on: April 26, 2015, 11:05:03 AM »
What version of Mach and what controller are you using.  Is the NUMLOCK on or off ??
Re: two issues....
« Reply #2 on: April 26, 2015, 12:33:14 PM »
I am using v 066.  Now I have another issue.
In a program with two different tools, when I change to the second tool and hit the "run cycle", the machine goes off the axis.
tony
Re: two issues....
« Reply #3 on: April 26, 2015, 01:46:45 PM »
V.066 has issues I would backup to V.062.
Re: two issues....
« Reply #4 on: April 26, 2015, 03:13:55 PM »
This is funny. I had v062 but could not get the M6start to work without a crash. l was told to go to the later version, and now I am having different issues.
I added some code to the M6Start, but the Z axis always wants to move up, past its safe limits and crashes.
I am simply stumped.
tony
Re: two issues....
« Reply #5 on: April 26, 2015, 04:21:05 PM »
What code are you running in the M6start I have never had any problem with it. Are you using SafeZ ?
