Hello Guest it is November 18, 2026, 12:26:27 PM
Author Topic: Space bar?  (Read 7255 times)
Space bar?
« on: April 24, 2015, 10:09:48 AM »
I have gotten hot keys to work through the Keyboard Inputs plugin for axis movement, however, there is no function for the space bar to be used as a feed hold?  Is this supposed to be automatically set?   :-\
I'm using the stock screen set that came with Mach4 and the only things I have added are the hotkeys for axis movement.
Thanks!
Re: Space bar?
« Reply #1 on: April 24, 2015, 12:03:29 PM »
In case anyone is interested, after a lot of digging I finally found this to map keys to inputs and then code what you want to happen when those keys are hit.
http://www.machsupport.com/forum/index.php/topic,27129.0.html
