Hello Guest it is November 23, 2026, 11:08:05 AM
Author Topic: return from sub  (Read 20125 times)
rswolff
Re: return from sub
« Reply #10 on: April 18, 2015, 02:33:58 PM »
because without some conditional jump....the entire program becomes a called sub-routine.....that works but its a fairly ugly approach......and I'm not impressed with $159 cost if it doesn't do what I would expect....and I never use steppers.....and unless I was brain dead I wouldn't use a parallel port as a control point. And there are many CNC controllers out there....I personally wouldn't spec this one for a project.
bob
Re: return from sub
« Reply #11 on: April 18, 2015, 05:21:18 PM »
10s of thousands of users would tend to disagree.
Have a good day, (;-) TP
Re: return from sub
« Reply #12 on: April 18, 2015, 07:48:37 PM »
bob,
Guess Mach3 is not for you. Respect your opinion,but, really disagree.
I hope you find a better controller for less and more applicable for all your CNC needs.
I certainly would be interested in what you would recommend along with your constructive evaluation of why it is better.
Till Then,
