Hello Guest it is November 22, 2026, 07:34:27 AM
Author Topic: mach3 question  (Read 8253 times)
mach3 question
« on: April 12, 2015, 08:52:24 PM »
hi , im retrofitting a machine with mach 3, pmdx 126 breakout board and panasonic servo drives and motors, i have movement on axis now , but always in same direction , mach3 displays show correct movement but axis goes in same direction, i can change motor output pin numbers and direction changes but still goes in only 1 direction same if i change parameter on drive , direction of movement changes but goes same direction whether jogged in + or - direction.
thanks
robert brintle
Re: mach3 question
« Reply #1 on: April 13, 2015, 01:24:34 PM »
Sounds like your Direction pin is either configured wrongly in Mach or there is an issue with the wiring to the drive from the breakout.
