Hello Guest it is October 12, 2026, 08:49:29 AM
Author Topic: only smal part in mach3 3  (Read 21522 times)
homecockpitbuilder
« on: April 19, 2007, 03:57:53 PM »
Hello,
When i put a dxf file in lazycam (newest version oncl mach3) and export it to mach3 the file only has a little part of the complete drawing on the tooltable. It is show in a jellow striped box and when i run the router it stops when it's on the stripe. Is this a problem somone now how to fix that?
Kind regards:
Bas
Re: only smal part in mach3 3
« Reply #1 on: April 19, 2007, 06:05:28 PM »
Hey Bas,
   Can you post a screen shot of your tool path screen and the g code file?
« Reply #2 on: April 19, 2007, 07:58:18 PM »
You can't load a spine in that rev... We hope to have that working soon :)
Brian
www.newfangledsolutions.com
www.machsupport.com
homecockpitbuilder
« Reply #3 on: April 20, 2007, 02:14:38 PM »
Hello,
Picture on this link:
http://www.homecockpitbuilder.com/mach3
Gcode on this file
http://www.homecockpitbuilder.com/gcode.tap
Hello Brain,
Can you explane what a spine means?
Regards Bas
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: April 21, 2007, 01:46:31 AM »
Is Mach running as a demo, you can only process 1000 lines of code in the demo and your file is 5600 lines long.
Graham.
homecockpitbuilder
« Reply #5 on: April 21, 2007, 03:04:33 PM »
Ok Graham, thats the problem. Do i need only a licence for mach3 or also for lazycam?
regards Bas
  •  2,785 2,785
« Reply #6 on: April 21, 2007, 03:07:44 PM »
The Mach3 licence covers the basic LazyCAM, if you want the pro version of LazyCAM its $50.00 more
Graham.
homecockpitbuilder
« Reply #7 on: April 21, 2007, 03:18:35 PM »
Hello Graham,
But when i only purcase mach3 its no problem to mill these file's.
regards Bas
  •  2,785 2,785
« Reply #8 on: April 21, 2007, 04:20:55 PM »
No problem at all, it will work fine.
homecockpitbuilder
« Reply #9 on: April 21, 2007, 04:26:30 PM »
Ok then i purcase a licence
Regards Bas
