Hello Guest it is October 24, 2026, 12:09:51 AM
Author Topic: Y axis missing steps while running gcode, smooth while jogging  (Read 22710 times)
Re: Y axis missing steps while running gcode, smooth while jogging
« Reply #10 on: April 01, 2015, 03:32:14 PM »
Here is a video of the current problem.
https://www.youtube.com/watch?v=xJVr9Eb6NDc
« Reply #11 on: April 07, 2015, 01:17:52 PM »
Is there any sort of menitoring possibilty in the plugin? If there is it will let you see if the controller is still getting commands and sending them out to the drives.
« Reply #12 on: April 16, 2015, 04:38:51 PM »
PROBLEM SOLVED!!!
The issue ended up being problems with the hardware.  I noticed some scratches on the C10 board.  I'm not sure if I caused them or if it came that way.  Either way, I bought a new one and the motors were able to jog again.  The problem with the Y axis ended up being a bad driver.  Automation Technologies replaced the driver and now everything is running perfect!
Thanks for everyone's help!
« Reply #13 on: April 17, 2015, 05:28:32 AM »
Good you got it :)
