Hello Guest it is October 12, 2026, 01:22:13 PM
Author Topic: Jog speed quit working  (Read 8251 times)
« on: March 15, 2015, 10:16:09 AM »
I had a power outage and after rebooting the system I can't adust the jog speed. Motors are set to 25 ipm in tuning but run at 12.5 when jogging. Doesn't change no matter what I set the slow jog rate to. Doesn't matter if I hold down the shift key or not. Also when I fired the system back up it gave me a external estop requested error even though my msr was pulled in. I had to change the active state in the ports in pins settings. Where should I look for this jogging issue? I rebooted a couple times and same issue.
Don
Re: Jog speed quit working
« Reply #1 on: March 15, 2015, 10:26:34 AM »
Ok found it. It reversed the active state on the limits and it was in override mode. I saw the light flashing in the settings screen. Any idea what caused this?
