Hello Guest it is November 22, 2026, 08:13:04 AM
Author Topic: Mach4 screen GRAPHICS -- makin' it Purdy  (Read 108982 times)
Offline Bodini
  •  216 216
« Reply #10 on: March 10, 2015, 05:24:28 PM »
I'm not at a computer right now, by try (tostring('VALUE') on the value you want to pass.
Offline Bodini
  •  216 216
« Reply #11 on: March 10, 2015, 05:26:17 PM »
Damn phone, damn Tapatalk... (tostring('VALUE')) is what I meant.
Re: Mach4 screen GRAPHICS -- makin' it Purdy
« Reply #12 on: March 10, 2015, 05:27:55 PM »
No problem, got that. I'll give it a try.
« Reply #13 on: March 10, 2015, 05:39:58 PM »
No joy.
Just to clarify, the 'Color' property is not working. Some of the others do work so I suspect this is just a dead ant.
ON/OFF and position work. It's sort of fun to make the thing jump all over the screen, but not particularly useful   :)
On the other hand, the 'hidden' property has no effect so jumping the LED into oblivion and back may be a workaround for making it 'disappear'.
In another thread, it was stated that some or the scr.********* command have been replaced by mc.*********, but so far I cannot find any mc.*********xx functions that even have the word 'prop' on them. I'll keep on tinkering . . .
Offline Bodini
  •  216 216
« Reply #14 on: March 10, 2015, 06:33:09 PM »
I poked at it a little here.
Code: [Select]
color = scr.GetProperty('led73','Color')
wx.wxMessageBox (color)
It reported back some numbers as I changed the Led. Red is 0, Purple is 32, Blue is 4. If these follow some convention, tell me about it. :)
« Reply #15 on: March 10, 2015, 06:38:46 PM »
It shouldn't be that hard to get some documentation on this stuff.
Just a simple list would go a long way.
« Reply #16 on: March 10, 2015, 06:50:22 PM »
Code: [Select]
You are wise, Obi-Wan!   :-*
That was the ticket. Reading out the codes was brilliant! Use those values and Bada-Bingg!  The colors change!
One big cookie for the man with the flag (the 'made in USA flag')
« Reply #17 on: March 10, 2015, 06:55:28 PM »
OK, time for some more fun. Checkboxes . .  I'm on it!
Somebody just say how they are supposed to work  . . and look.
Do you just want a Boolean?  . . can do . . but it just seems so . .  minimalist . . .  ;)
« Reply #18 on: March 10, 2015, 06:59:45 PM »
Wouldn't cascading checkboxes be more fun?
Check . .
    Are you sure ? . . . .
      But are you REALLY sure? . . . .
       Is that Really REALLY SURE? . . .
        Do you have a note from your MOTHER? . . . .
OK, just say how they should work and I'll see if I can make them up . . .  :(
« Reply #19 on: March 10, 2015, 07:06:25 PM »
Idea . . .
How about instead of boring check box, a push button? Same control, but lookin' good?
Mo' better . . .
How about a toggle switch?
Actual toggle switch? Oh yeah! Looks real? Oh yeah - a photo of a real switch . . Moves?  . .  oh yeah  . . Handle lights up?  . . Oh YEAH.    ;D
 I already have the transparency part (alpha channel) working . . . just need to get rid of the button outline as it looks a bit stupid just popping up out of nowhere.  :-\
« Last Edit: March 10, 2015, 07:10:42 PM by simpson36 »
